RPSU questions
Blake Smith
RPSU questions
Post by Blake Smith » Sun Jun 11, 2017 2:16 pm
Hi there,
I'm putting together an RPSU with the intention of powering an HVM and SE330, and will be using a single phase 16v 1000ma AC adapter.
I wasn't reading the build document close enough and I went ahead and soldered in D9 and D9, however they are indicated as not needed in the case of a single phase supply. Will it hurt anything if they are left in place, or should they be taken out?
Also, just so I understand the ripple requirement on the 1000u electrolytic caps, the 750ma ripple requirement is a minimum rating, so if the cap has a higher ripple then it should be more than adequate?
Thanks,
Blake.
Synthbuilder
Re: RPSU questions
Post by Synthbuilder » Mon Jun 12, 2017 2:39 am
Blake Smith wrote:Will it hurt anything if [D9 & D10] are left in place, or should they be taken out?
You can leave them in place - they'll not affect anything.
Yes. The higher the better - although the higher rated ones are usually physically bigger and more expensive.
Tony
