Expert Sleepers ES-8
Author Expert Sleepers ES-8
apcuddling
Super interested in one of these.
Anybody used one? Thoughts?
ccastellanossf
You may want to check the Expert Sleepers forum. That said, I have one and I am very happy with it.
Muse FTW
I don't use the ES-8 but I do use the combo of ES-3/6 instead (lightpipe through the audio interface instead of through USB) so it's a little different, but it serves its purpose well.
I haven't tried the software (Silent Way) but I mostly use the output for sending audio loops through to the Eurorack via Ableton. I use the input for recording my whole system in different in ports, allowing me to get the levels just right when mastering tracks afterwards and stay in the moment when creating.
cryptogreen
I bought two and think they have really improved the quality of my sleeping. Dead Banana Seriously though, I find being able to design modulation on the computer for given patch has really changed my module make-up and being able to record directly to the DAW is obviously really nice. The only case I have heard against it is that you need to buy software to generate cv in order to get the most out of it.
Xtheunknown
Love my ES-8! I use it with Reaktor Blocks, mostly for outbound control voltages, sequences and digital oscillator out to the modular. Planning for an ES-3 expansion soon as well.
Jtalton
i was wondering, i have a apollo 16 which handles all my audio I/O needs but i would love to add this to handle my reaktor / maxmsp CV i/o in live. Would i be able to set up both the apollo and the ES-8 at the same time in my daw (live / reaper).
Are any of you using a audio interface and ES-8 in one DAW at the sametime?
mattb
I have got one.
Using it as soundcard (USB) with an IPad Pro and an iMac.
I use it also as an optical ADAT interface to extend the number of I/O on a Apogee Ensemble Thunderbolt.
Works great both ways.
dumbledog
Absolutely indispensable.
Unifono0815
I have one too. Works flawlessly.
Use it with Reaktor Blocks for seqencing and modulation and to get the rack sound back in the computer, using effects.
Xtheunknown
Yes - I'm using my ES-8 with an M-Audio interface as a Mac aggregate device in Cubase. No issues.
Unifono0815
Me too. ES-8 and NI Komplete Audio in Ableton (or Reaktor) as mac aggregate device.
apcuddling
I guess I was mostly concerned with how well it worked. If it was easy as it seems it would be.
Alright, guess I gotta get one now.
Thanks everybody!
Funky40
is it as simple to create a agrregate device as described here ?
https://support.apple.com/en-us/HT202000
.../utilities/audio-midi/...create
or can it be stressy ?
still waiting for the new batch to come in to get mine wink
( i have also a NI komplete kore6 )
tommygee
It's super easy to set up the aggregate device razz mine has worked perfectly. Using mine for audio/CV back and fourth between my modular and daw.
stjohn909
ES3/Silent Way user here. It's a little weird at first, thinking of voltage while looking at a DAW screen, but it really is a super-useful tool. I went with the lightpipe version because the price was right and I didn't have to worry about making 2 audio interfaces work together in ASIO on Windows.
Mostly what I love about it is the way it bridges the gap between DAW and modular so seamlessly. Sync/clocks are the immediate, obvious benefit.
There is some fiddling (but not much) to tune and calibrate your VCO, but once that's done, you can sequence notes with impunity. But I think where it's helped me most is I can use it to paper over the fact that I'm missing some basic, necessary modules for modulation, triggers, and gates, and the way I use the Silent Way plugins is helping me to determine which modules I need to concentrate on purchasing next. It also helps me get more of of my Maths than I would be able to with the tiny collection of modules I currently own.
dumbledog
Yep. I have it set up as an aggregate with my MOTU, and the ports I don't use (ADAT etc) are hidden. The modular is usually turned off. When I want to make music I just turn on the modular, start up Logic and Everything Just Works. I have a template in Logic with the inputs assigned to channel strips (1, 2 and 3-4 as a stereo pair).
About the only sticky point is latency, which while not terrible is enough so that you can't do ridiculous stuff like modular oscillator --> ES-8 --> software filter --> ES8 --> Modular VCA without running into timing issues, but oh well.
Funky40
Thanks for the feedback dumbledog and tommygee !
Moon Indigo
Have one, it's working great, using it to send CV from blocks to hardware (sequencing, modulation), and to send audio to hardware (e.g. additional osc on Mother 32.
It's working GREAT with my Mother 32, System 1m, and 0 Coast.
I am running is as an aggregate device in El Capitain together with Focusrite Scarlett 6i6. No issues.
I have sequenced using CV pitch / gate from both Numerology (has to calibrate first using Silent Way) and from Reaktor (calibrated using the Pitch/CV Block).
Sequencing is flawless (except if I sequence all my 3 semi modular it eats up 6 of the 8 outs of the ES-8, so have tended to use some midi).
Happy customer. Happy to answer any questions.
dr33m3r
Hi,
I have had an ES-8 for a couple of days and have to say that using it to integrate my hardware rack and my VCV Rack software modular is truly amazing. It just works, as they say. CV in and out gives me a truly hybrid system with real and virtual modules working together beautifully.
I have noticed one thing that is potentially problematic, though, in the area of audio quality. It seems that audio out of a VCV Rack patch via ES-8 is noticeably lacking high end when compared to the same output patched directly into my Universal Audio interface, with both going to the exact same studio monitors.
Has anyone else noticed this? Am I just noticing that my Universal Audio DAC is really good?
Don’t get me wrong, I am not getting rid of my ES-8. It is worth the price of admission even if only used for CV. I’m just curious if anyone else has any thoughts on the ES audio quality.
