Joranalogue TEST 3 - Eurorack V/mA Meter
Author Joranalogue TEST 3 - Eurorack V/mA Meter
joranalogue
Available now! https://joranalogue.com/pages/dealers
Test 3 is a purpose-designed tool for measuring voltages and currents in your Eurorack system. This means that just a single circuit board or module can now replace a convoluted test setup with multiple multimeters, custom cables etc.
Two push buttons allow you to cycle the value shown on the LED display between three measurements (voltage, current and stored peak current) of the three power rails. The peak currents continually update in the background on all rails, making it ideal for quickly getting maximum current figures.
Apart from measuring the current draw of a single module, Test 3 also supports testing power supplies and cables, measuring an entire system (up to 1 A of current on each rail), troubleshooting DIY modules, powering a skiff from a larger system...
Note: Test 3 is available as a (very easy) do-it-yourself project, requiring some soldering and basic tools. It can be built either as a standalone circuit board with the DIY Kit, or as a Eurorack module with both the DIY Kit and Front Panel Kit. This is a great beginner project if you're just getting into synth DIY!
Gearslutz video: https://www.youtube.com/watch?v=tXIxQNawiMg&t=13m46s
More info: https://joranalogue.com/products/test-3
ModularGrid: https://www.modulargrid.net/e/joranalogue-audio-design-test-3
Pricing
• Without front panel: €70 / £65 / $80 (MSRP)
• With front panel: €95 / £85 / $110 (MSRP)
8 HP, 28 mm deep when built as module
c0nsumer
This looks really neat. Does it offer protection for the main PSU in the event that the attached module somehow fails?
That is, would this be appropriate for testing unknown-state newly-built DIY modules or used-purchases or whatnot?
joranalogue
There's no real overcurrent protection, because something like a polyfuse would cause too much voltage drop, especially at 1 A. A more advanced way would be to switch off the rails electronically, but that method has a bunch of issues as well (more components on an already crowded layout, and voltage drop again to a lesser extent).
At any rate, your PSU should have reliable overcurrent protection. T3 does handle pretty large overloads, and has reverse-polarity protection on all rails + noise filtering. So it's protected to an extent. Hope that answers your question!
acgenerator
I'll be getting one of these for sure.
joranalogue
Hi all,
Test 3 was going to be available this month, but I hit some delays. The design is ready to go, I just have to wait for some suppliers.
I hate delays as much as the next person, but that's Eurorack I guess. Dead Banana
They should pop up at dealers in September! MSRP will be €70 / £65 / $80 without front panel, €95 / £85 / $110 with.
joranalogue
Available now!
The wait is over! EU folks can get Test 3 directly from the webstore now, and they're coming to dealers worldwide soon (to be announced).
It's peanut butter jelly time!
joranalogue
Now also in stock at Thonk (UK) and Modular Addict (US). applause
joranalogue
Watch Quincas Moreira aka the Synth DIY Guy build Test 3! Includes a very nice step-by-step overview of the build and measurement demo.
Now also available at Perfect Circuit Audio (US).
joranalogue
Delighted to announce that Test 3 is now also available at SynthCube! http://synthcube.com/cart/joranalogue-test3-euro-kit
monads
Such a handy little module! And easy to build (Thonk) too! Thanks!
joranalogue
Hey, that's great to hear! thumbs up
By the way, if anyone's wondering if this is a good DIY kit to start out with... It absolutely is! Here's a review by Little Modular - this was his first ever kit:
joranalogue
The new production batch has arrived! Now back in stock at the Joranalogue webstore and soon also at Exploding Shed.
With this new batch now available, the circuit schematics and firmware have been open-sourced. This means you can develop and publish alternative firmware for T3, or use it as a basis for your own designs. Find the source files on GitHub.
spacenoodle
When using this to monitor power going to DIY modules on a breadboard, would the circuitry in Transient Modules Breadboard Power be redundant (as this module has the protection and filtering built in)? Maybe just run the power straight from the output of Test 3 to the rails/terminal strips on the breadboard?
https://www.thonk.co.uk/shop/transient-breadboard-kit/
joranalogue
Yes, Test 3 has built-in reverse polarity protection and filtering built-in, so you can power a breadboard directly.
Please note that neither Test 3 or the Breadboard Supply have overcurrent protection, so your PSU should be properly protected in that regard.
