Hi,
I have a weird issue with the USAMO. I've been able to use it pretty flawlessly for a long time. Unfortunately it showed some issues lately.
So, in a blank set in Ableton Live, the Cirklon is starting and syncing perfectly each time I press play. But as soon as I have recorded some tracks, it begins to not start each time. With about 20 tracks of audio and a few MIDI recorded, it just works like 1/30 times. I tried to turn off every track except USAMO and this is the same. Just after experimenting this I save and go to a blank set and it works everytime, then go back to the previous saved project and the issue is still the same. The MOTU 24I/O well sends the audio to the USAMO and this last well shows that it receives it on its LED, but the Cirklon doesn't start.
I tried the setting "delay start" on the USAMO controls and this helped to reach a somewhat 1/15 probability.
This is very annoying... Anybody did ever experiment this ?
USAMO start issue with Cirklon, Ableton Live and MOTU 24I/O
The fact that 'delay start' improves things points to this being the same long-standing bug in Live that that control is designed to cope with. It's worse with complex projects, which is probably why you don't see it until you have a full song going.
Are you using the 'external audio effect' device to send out the USAMO's audio?
It would be great if Ableton would actually fix this. If you'd like to email their support, refer them to my case ableton1401056 about this bug.
No, should I ?os wrote: Are you using the 'external audio effect' device to send out the USAMO's audio?
I wasn't expecting to contact the Ableton support as I don't know what's going on and produce the issue.It would be great if Ableton would actually fix this. If you'd like to email their support, refer them to my case ableton1401056 about this bug.
So it's not possible to use the USAMO flawlessly with Live ?It's worse with complex projects, which is probably why you don't see it until you have a full song
It's an option. Some people find it helps their workflow.No, should I ?
You know that when a set becomes complex one of your plug-ins stops behaving correctly, because of a bug in Live. If nothing else, just email them and say "this is affecting me". The more people tell them a bug is affecting them, the more seriously they'll take it.I wasn't expecting to contact the Ableton support as I don't know what's going on and produce the issue.
It's working flawlessly for many people. It's not entirely clear why some people run into this issue.So it's not possible to use the USAMO flawlessly with Live ?
