Blacet Dual Filter bare PCB cap- and IC question
e-grad
Post by e-grad » Tue Oct 07, 2008 8:40 am
Hi list, this is my first posting and I'm coming right with two questions. Hope to contribute later myself!
I've got two Blacet Dual Filter bare PCBs and two questions regarding them:
1) The BOM asks for mylar caps (C1; C2; C5; C6) which are hard to come by in my part of the world. Thus I'd like to substitute them for polystyrene. Is that fine or a little over the top?
2) I need in total four MAX365 ICs, alas, I could track down only two. Any source?
BTW Blacet hast still some Dual Filter bare PCBs. After having heard some samples (I think by Kwote), I think it a very nice Filter. However, if you buy one or more take the knob kit as well if you want to pcb mount the pots since two of them have 6 pins each which should not be easily to find elsewhere.
Kwote
Voltage Controlled Crackpot
Post by Kwote » Fri Oct 10, 2008 12:40 am
wish i could help. both my DF's were built from parts supplied by Blacet.
kwotemusic.com
my other sites
neandrewthal
full clout y'all
Location: Spending warm summer days indoors writing frightening verse to a buck-toothed girl in Luxembourg
Post by neandrewthal » Fri Oct 10, 2008 1:00 am
Polystyrene would be fine. They are actually better than mylar but you probably wouldn't notice the difference in a manual filter. I'd suggest going for polyester if you can find them for cheaper than the polystyrene.
Initiate the sequence, create catastrophe.
e-grad
Post by e-grad » Fri Oct 10, 2008 4:59 am
Thanks for your replys! So I go for poly caps.
Return to “Fractional Rack Modules”
