Boosting Low Output Level Modules?
cheapmachines
Post by cheapmachines » Fri Jun 30, 2017 5:47 am
I use the Epoch Modular Benjolin module but would like to be able to boost the levels coming from the filter outputs as they always seem rather low.
My VCA's all max out at unity, what are the clean level boost options in Euroland? Nothing outrageous, just to bump the signal up so it's comparable to other modules.
Any low hp clean level boosters out there? Not looking for overdrive / distortion modules.
dubstephead
Post by dubstephead » Fri Jun 30, 2017 6:13 am
Can't get it to modular level running through a vca at max?
What vca are you using?
mharpum
Post by mharpum » Fri Jun 30, 2017 6:14 am
I use streams for this but there is probably a cheaper option. I think blinds can do this as well.
https://soundcloud.com/mark-harpum
https://www.instagram.com/harpum1/?hl=en
https://www.modulargrid.net/e/racks/view/456680
FS/T loquelic v1, korgasmatron 2 w/ expander, zdsp w/ 4 cards, seq 1, control forge, rt60, English tear(faulty),
WTB anything WMD and Noise Engineering.
cheapmachines
Post by cheapmachines » Fri Jun 30, 2017 6:19 am
It's at modular level alright, what I meant is the level from the module is low and my VCA's don't make it any louder. Some VCA's will boost but not all. Nothing wrong with the Benjolin, just how they are.
There are a few threads on Muffs already covering this and the advice seems to be the 4hp ADDAC Amplifiers, Circuit Abbey Gozinta or Doepfer A-183-3 for raising levels. Just wondered if there's anything else or if these three are still a good bet?
Avjr
Post by Avjr » Fri Jun 30, 2017 6:24 am
Had the same need so this is what i did: i ditched a couple of vca's and got a Intellijel Quad VCA instead that has boost switches on all channels. Works like a charm.
nimmen
Post by nimmen » Fri Jun 30, 2017 6:29 am
I'm also having similar problems, probably something like A-183-3 is made for that purpose?
http://www.doepfer.de/a1833.htm
Regarding modules with low output, one example would be j3rk dual bandpass filter I'm using.
busy soldering...
abdul6
Post by abdul6 » Fri Jun 30, 2017 6:31 am
so for me two solutions for my Benjolin :
clean : Benjolin -> Gozinta
overdrived : benjolin -> TipTop Fold
SB-SIX
Post by SB-SIX » Fri Jun 30, 2017 8:29 am
Pico input might be a good option. 2 channels, 3hp and not too expensive.
There is a chance you might like this: https://soundcloud.com/steeboo
cheapmachines
Post by cheapmachines » Fri Jun 30, 2017 8:57 am
Thanks for the suggestions, very helpful 8-)
abdul6 wrote:clean : Benjolin -> Gozinta
How do you have the jumpers set on the Gozinta to give a good clean boost for the Benjolin? Are you on 12, 24, or 36dB?
I have a 1u row and am thinking this might do the job if 26db max seems like it would be enough for most purposes?
http://pulplogic.com/product/gain/
Konrad Seifert
Post by Konrad Seifert » Fri Jun 30, 2017 9:20 am
I use this http://www.schneidersladen.de/de/erogen ... evit8.html
or this
http://www.doepfer.de/A133.htm
the latter if I need voltage control.
I also have the Vermona TwinVCamp which can boost a signal x4, but it distorts (in a good way) which is not always wanted.
kwaidan
Post by kwaidan » Fri Jun 30, 2017 9:39 am
MI Veils will give you a maximum gain of 2 (+6dB) in linear operation and 10 (+20dB) in exponential operation.
pricklyrobot
Post by pricklyrobot » Fri Jun 30, 2017 9:43 am
If you've got a 1U row that will accommodate it, the Pulp Logic 'Gain' tile is cheap and handy.
Edit: a closer read shows you've already beat me to this suggestion;)
Anyway, I have and recommend the Gain. Good, clean boost in a small package :tu:
cheapmachines
Post by cheapmachines » Fri Jun 30, 2017 10:28 am
pricklyrobot wrote:Anyway, I have and recommend the Gain. Good, clean boost in a small package :tu:
Ah, excellent - nice and quiet in operation and all that good stuff? Probably going to go this route as I like to keep utility stuff in the 1u line as far as I can.
pricklyrobot
Post by pricklyrobot » Fri Jun 30, 2017 10:56 am
cheapmachines wrote:nice and quiet in operation and all that good stuff?
Yep.
I use it mainly to boost the output of my OP-1 so I can patch it into the modular. Haven't ever noticed any excess noise.
cheapmachines
Post by cheapmachines » Fri Jun 30, 2017 11:07 am
:sb:
Thanks for the other suggestions in this thread, quite a few I haven't come across before.
dubstephead
Post by dubstephead » Fri Jun 30, 2017 12:17 pm
cheapmachines wrote:It's at modular level alright, what I meant is the level from the module is low and my VCA's don't make it any louder. Some VCA's will boost but not all. Nothing wrong with the Benjolin, just how they are.
Yeah I understood what you meant originally :tu:
It is not working at a normal modular level though, Eurorack's nominal operating level is very high, (professional line level is +4dBu and euro's easily operate 6 more dBu than that) so if it was operating in this range it should be as loud as you could ever want (unless your main out or speaker were the problem, which they obviously aren't)
The reason I asked what Vca you were using is because most vca's should provide a decent amount of gain. They are voltage controlled amplifiers after all :hihi:
The amount of gain in dB's each vca provides can almost always be found in in the description or documentation for the module.
I have a Folktek Matter which also has a very low output and I can turn its volume down by more than 50% till its very quiet, then run it through a channel of my Zlob vnlcursal vca and just by turning up the vca I can get it too loud for comfort.
Also for a temporary fix, if you are able to get some gain out of your current vca, you can run you its out directly into another vca (repeat if needed) till the levels are good.
Hope that's helpful.. :tu:
hippasus
Post by hippasus » Fri Jun 30, 2017 12:24 pm
I use optodist from RYO it works great with the benjolin.
cheapmachines
Post by cheapmachines » Fri Jun 30, 2017 1:09 pm
dubstephead wrote:The reason I asked what Vca you were using is because most vca's should provide a decent amount of gain. They are voltage controlled amplifiers after all :hihi:
Yeah, know what you mean - mine (Ladik and 2hp) run from zero signal passed with the gain fully anti-clockwise to unity fully clockwise as far as I can tell i.e. the same as the original input level. Some VCA's like the Intellijel uVCA for instance can boost beyond the original signal level but mine don't do that.
Chaining VCA's together is a good temporary fix, thanks.
strangegravity
A Big Knob
Post by strangegravity » Fri Jun 30, 2017 1:18 pm
PGH INOUT has a gain switch. These can be had for under $70 used.
Aaronautical001
Post by Aaronautical001 » Fri Jun 30, 2017 1:22 pm
Another vote for veils.
Shledge
Post by Shledge » Fri Jun 30, 2017 5:33 pm
I've a few old doepfer filters which are very quiet in comparison to other modules, and Veils does a good job on amplifying them.
I asked Dieter on mods for them, but all seemed to be in regards to increasing their inputs - not ideal because they'll get easily overdriven.
Paranormal Patroler
Post by Paranormal Patroler » Wed Jul 05, 2017 7:40 am
I went for Ladik for this usage. He has two 4HP options (maybe more?) which can bring line to modular level. One is with attenuation, one is without but has four inputs/four outputs which I think is really nice. You can attenuate post the drive.
EDIT
cheapmachines wrote:There are a few threads on Muffs already covering this and the advice seems to be the 4hp ADDAC Amplifiers, Circuit Abbey Gozinta or Doepfer A-183-3 for raising levels. Just wondered if there's anything else or if these three are still a good bet?
I always considered the ADDAC202 to amp my 302 to +10V but I never got one. They are on sale though :hmm:
Here's the link to the Ladik A-520: http://ladik.ladik.eu/?page_id=1143
abdul6
Post by abdul6 » Wed Jul 05, 2017 8:09 am
for Gozinta jumper :
24db is fine for Benjolin, always works
Shledge
Post by Shledge » Wed Jul 05, 2017 10:54 am
What about Ears? Apparently it's good for this, amongst other things.
Pighood
Post by Pighood » Wed Jul 05, 2017 11:46 am
Had no idea Gozinta even had a jumper until just now. :eek:
*phnert*
