New module: Dual Sequential Switch for Buchla format
sempervirent
Post by sempervirent » Fri Jul 07, 2017 1:35 am
I've been working on this one for a while... a Dual Sequential Switch for Buchla format.
Primarily it's intended as a companion for the 245/246 sequencers, extending their range from 5 to 20 or 16 to 64 steps respectively. The jacks for the Stage Select inputs and Active channel outputs are borrowed from the 245/246 paradigm as well. Of course the 4-way setup also pairs nicely with the many other "quad" modules in the Buchla world such as the 281 and 292. The main I/O is bidirectional, meaning that the module works as a 4:1 multiplexer or a 1:4 demultiplexer.
CV control over Length and Mode is provided (scaled to a 0-10V range, although negative voltages are also supported if you want to subtract instead of add to a value). The "L.BND" output is for Length Boundary... a pulse is generated whenever the length changes (whether manually or via external CV). Cross-patching the top and bottom sections together also creates a lot of possibilities for complex rhythmic interaction.
The module can be built with your choice of bananas or Tinijax on either or both sections (not just bananas as shown in the illustration above). The main I/O circuitry is designed to handle both AC and DC signals, it's just a question of installing one type of jacks or the other.
Retail price is going to be in the $400-500 range, hoping to be shipping these in September. Assembled only, no DIY option. Please comment here or send a PM with your name, email address, and location if you want to get on the waiting list for the first batch.
Here's a photo of the prototype. Tinijax on top, bananas on bottom. Final panel will be brushed and silkscreened, fabricated by the same shop that DIY Hub (200r panel provider) uses.
lasesentaysiete
Post by lasesentaysiete » Fri Jul 07, 2017 2:25 am
pleasantly surprised by your pricing. On this and your other recent marvels :)
The work is great, too!
KSS
Post by KSS » Fri Jul 07, 2017 8:28 pm
Looks nice! You may want to consider this exchange of jack and button in the upper half of each unit. Freeing the manual buttons from being boxed in when patched. Image
synthi
Post by synthi » Fri Jul 07, 2017 9:57 pm
Nice!!! Interested! Please add me to the waiting list
:bananaguitar:
Kymátika studio | facebook | soundcloud
Recording - mixing - mastering
sempervirent
Post by sempervirent » Sat Jul 08, 2017 11:16 pm
lasesentaysiete wrote:pleasantly surprised by your pricing. On this and your other recent marvels :)
Thanks. In the MI conversion thread someone mentioned the "Buchla tax" – doing Buchla stuff is more expensive than Eurorack due to the larger PCBs and panels, certain more expensive components like Tinijax, and also due to the time involved in wiring all the jacks (it's a lot more work than soldering a bunch of 3.5mm jacks directly into a PCB). But I'll try to keep things reasonably priced.
KSS wrote:Looks nice! You may want to consider this exchange of jack and button in the upper half of each unit. Freeing the manual buttons from being boxed in when patched.
There actually was a design iteration like that early in the process, but I couldn't "unsee" the two adjacent jacks being interpreted as Reset inputs. Consistently having labels above all of the jacks make this more clear IMO. In actual usage the Trig button is easy to reach, even when patched all around.
synthi wrote:Nice!!! Interested! Please add me to the waiting list
Sure, thanks a lot – will PM you for details.
KSS
Post by KSS » Sun Jul 09, 2017 5:51 am
sempervirent wrote: There actually was a design iteration like that early in the process, but I couldn't "unsee" the two adjacent jacks being interpreted as Reset inputs. Consistently having labels above all of the jacks make this more clear IMO.
yes. I noticed that also, and made an update.
Glad you find it works for you. Buchla patches get dense and for me it will be better outside the corral. Either way, still a nice module idea and realization!Image
sempervirent
Post by sempervirent » Thu Jul 20, 2017 1:29 pm
Just fine-tuning the calibration procedure on this one, hope to post some demos soon.
woVERTICES
Post by woVERTICES » Thu Jul 20, 2017 3:53 pm
Great looking module!
Best,
John
www.johnjpotter.com
exeterdown
Wiggling with Anxiety
Post by exeterdown » Sat Jul 22, 2017 12:25 am
Its nice to see new life being breathed into the format - and as with the prime example of the Pendulum/Ratchet - not just any old function but things with a Buchlidian flavour.
Took me a bit of time, but I think I'm starting to wrap my head around it.
I think it was the bi-directionality that confused me: IN/OUT
Can this be used as a sample and hold?
So, as a 1in4out - would the output hold the last value sent to it, until it was selected again?
sempervirent
Post by sempervirent » Sat Jul 22, 2017 10:29 am
Think of it as a room with four entrances and one exit (4:1) or one entrance and four exits (1:4). There's no real difference between entrances and exits, it just depends on which direction you are moving. And only one of the four doors (whether entrances or exits) can be open at any given time.
You are sort of describing a shift register (like the SynthTech E102) but the 1:4 setup is about routing a single input to one of four outputs, not holding a voltage at its current value until changed. Different concept.
The I/O could also be patched with audio, not CV, so it's not really about holding on to CV signals. It's about opening and closing one of the four doors so that you control the signal flow.
exeterdown
Post by exeterdown » Sat Jul 22, 2017 6:51 pm
Yep yep, I get you.
Like, if I have a fluctuating random source as an input, and four oscillators as outputs, only the currently selected oscillator will fluctuate randomly.
So do the other three maintain their last value, or drop to 0V?
Is there a logic behind why they do either?
sempervirent
Post by sempervirent » Sat Jul 22, 2017 7:25 pm
Right, the fluctuating CV would only go to one of four oscillators. Or going in the other direction, you could have four different envelopes patched to the four inputs and route them to a single VCA.
Inactive channels are completely disconnected, otherwise there would be undesirable summing or mixing and whatever signal is passing through the module would be transformed.
The reason the channels don't maintain their last value is because that would be a totally different type of module (shift register). There are 1:4 shift registers and 1:4 sequential switches but that's where the similarity ends, the circuitry and concepts are not the same.
sempervirent
Post by sempervirent » Sat Jul 29, 2017 3:58 pm
Got some bad news on this one, the microcontroller is backordered until October at the earliest! Something to do with Microchip/ATMEL retooling their production line as part of the merger. So it goes.
Still need to do a little testing anyway, just wanted to post an update. Apart from a calibration procedure bug and a few resistor tweaks, it's otherwise working well.
mutierend
Post by mutierend » Mon Apr 16, 2018 5:37 pm
How is this looking these days, sempervirent?
sempervirent
Post by sempervirent » Mon Apr 16, 2018 11:46 pm
Thanks for asking. It's somewhat of a lower priority than the Buchla-format Clouds, Rings, etc modules but it's still in the queue. It's pretty close to being done, just needs a few firmware and resistor value tweaks.
jondent
Post by jondent » Tue Apr 17, 2018 3:38 am
looks great :nana:
mutierend
Post by mutierend » Wed Apr 18, 2018 11:37 am
sempervirent wrote:Thanks for asking. It's somewhat of a lower priority than the Buchla-format Clouds, Rings, etc modules but it's still in the queue. It's pretty close to being done, just needs a few firmware and resistor value tweaks.
Cool. I just want to make sure builders like you know you have our support. :)
hydrophilos
Post by hydrophilos » Wed Apr 18, 2018 1:59 pm
Add me to the waiting list too--thanks!
sempervirent
Post by sempervirent » Thu Apr 19, 2018 1:42 pm
mutierend wrote:Cool. I just want to make sure builders like you know you have our support. :)
Thanks, really appreciate that. I'll keep this thread updated as things evolve.
Post by Kent » Fri Jul 06, 2018 4:15 pm
Still keeping my eyes open for that Sequential Switch module. :eek:
tobb
Post by tobb » Fri Jul 06, 2018 4:45 pm
The cv control is a great feature! :tu:
KoryB
Post by KoryB » Sun Jul 08, 2018 2:08 am
:banana:
Looks fantastic!
levelhead3
Post by levelhead3 » Mon Jul 09, 2018 12:20 am
Yep. There will be a space next to my 245 waiting for this one! :yay:
sempervirent
Post by sempervirent » Wed Jul 11, 2018 8:30 pm
Thanks guys. Just looked back at my first post. Shipping in September – ha!
Haven't forgotten about this one, will post details here once it's ready for release.
Pailo
Post by Pailo » Fri Oct 12, 2018 2:07 pm
yea im ready for this for sure, it would
make the 245 and 266e go crazy.
