FH-1 USB doesn't light up ( SOLVED )
Author FH-1 USB doesn't light up ( SOLVED )
RubberGong
Using the Fh-1 with the Pyramid. Bought it second hand. Updated the firmware, and erased configs.
I just get clicks when connecting the FH-1 to 1v/oct input? Using output 1.
The USB lights do not light up.
The Pyramid is powered via the FH-1, and is functioning as expected. I have set track on USB midi channel 1, sending cv.
when i monitor the outputs on the DATA - they are all -5 volts approximatly. Running 2.1 OS on pyramid.
Tried sending midi usb to Ableton from pyramid, and that works fine.
- And NOW IT WORKS after a reset smile hurra
