[SH-1oh1] Auto portamento bug
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
goldplate
Post by goldplate » Mon Jul 17, 2017 10:01 am
v. 1.07
I can't get any auto portamento on the higher notes.
Did someone notice this also ?
tubbutec
Post by tubbutec » Mon Jul 17, 2017 3:15 pm
This is probably because you are using the extended pitch range feature. Outside the normal range, portamento does not work properly.
Can you specify for which notes auto portamento is not working so I can check?
goldplate
Post by goldplate » Thu Jul 27, 2017 2:36 am
Difficult to say, as it's only between certain specific two notes and combined with the different notes numbers nomenclatures...
But for example try to play an octave up and down of some higher C's, and then other notes also, if this is an universal bug, you should find it.
tubbutec
Post by tubbutec » Thu Aug 17, 2017 6:06 am
The thing is the auto portamento is not generated in the CPU but by analogue circuity. It does however not work properly when using the extended pitch range via midi..
Return to “Tubbutec”
