Cocteau V1 (by Autonomik Circuits) Build Thread
Author Cocteau V1 (by Autonomik Circuits) Build Thread
effegee
Cocteau V1 (by Autonomik Circuits) Mod PCB for your YOCTO
All first run kits have shipped.
Here is the link to the Cocteau V1 Build Docs v1.0
If you have some cool mods you would like to share, feel free to post them in this thread.
Mouser BOM changes:
8 August 2017: 2-pin header (part #571-6404572) quantity increased from 1 to 3
FAQ:
What is the clay-like stuff in the kit?
It is poster tack, which is used to hold the Q28 transistor in place while soldering (see P. 9 of the build doc) and to hold the screws in place when joining Cocteau to the YOCTO (P. 21).
Why are there DP3T slide switches?
The other 500 series SPDT switches are non-shorting, or "break-before-make"(BBM), switches, which can cause the oscillators of some voices to fire when switched (see example of SD sound here). The shorting, or "make-before-break" switches were chosen because they eliminate this effect.
Where is the SK30a? It doesn't look like it came with the kit.
It's encased inside the pink foam in one of the plastic bags.
Rxke
Very nice doc!
I had a bit of a problem viewing it on an older laptop though, but on my main computer no problem.
Paradigm X
Awesome build doc thanks!
Bit daunting eek!
If you had an unbuilt yocto would you build it stock first then desolder or just dive in? I can see pros and cons both ways.
Many thanks!
Ben
MrRoper
fwiw I built my Yocto first just to verify it works, it doesnt seem too much to desolder, however trying to find what board has a fault on could be a bit of a bore.
Does look like a daunting build but looking forward to it!
MrRoper
Was there meant to be an sk30a included in the cocteau kit? Build docs suggest so but I didn't get one. Anyone in UK/EU have a source or a spare they'd be willing to part with?
effegee
The SK30a is inside of the pink foam in one of the plastic bags. Also, I tested each of them individually before shipping, so there are no duds.
MrRoper
Thanks! Found it, I put that little baggie to the side and nearly missed it!
Can anyone in the UK help me source a 2MB pot for the CP density mod (my enclosure has a hole for it already)? Everywhere I've looked doesn't have them, including tayda/ bitsbox.
Also on the Mouser BOM i think you need to add 2 more of:
Mouser No: 571-6404572
Mfr. No: 640457-2
Manufacturer: TE Connectivity
Desc.: Headers & Wire Housings FRICTION LCK HDR 2P Right Angle Post tin
As there's only one on the BOM and I think we need 3 (J15, J27 and J29)?
Getting close on mine!
nanners nanners
effegee
The 2M pots are a custom order, which is why they are included in the kit.
Four 2M(B) pots shipped in the kit, one each for:
- SD Tune 1
- CB Decay
- CP Density
- Extended CP Density (this is an "optional" mod, so the pot could be used for any other user mod, if desired)
Note: The SD Tune 1 and CB Decay pots are listed as "2M(A) in the build doc. They are actually 2M(B).
Mfr. No: 640457-2
Thank you for the heads up. BOM has been corrected to increase the quantity to 3.
Paradigm X
is it possible to use molex KK instead of mta connectors? only because i already have a load of them and no mta tool
cheers
effegee
I don't have any KK connectors on hand to check. You can use them if you think they leave enough space for the wires between the housing and the back of the enclosure. Try it and see.
Paradigm X
ok thanks. my enclosures not arrived yet so im not sure about spacing etc. ill check it out when it arrives.
so long as its not a 'it definitely wont work' ill have a look when it arrives.
cheers
ben
rasi
I was wondering if the Cocteau clap mods would be compatible with the BA662A chip, as I've always found the VCA used in the yocto for the clap to be just a tad too clean.
I intend on following the mod described here so pins/resistances match
http://www.e-licktronic.com/forum/viewtopic.php?f=18&t=1194&p=7567&hil it=yocto+ba662#p7567
Otherwise, I have the Cocteau mod completed entirely and I'm just waiting for a case! Finally fixing the clap would be icing on the cake.
Thanks for all your effort
effegee
I haven't tried it, but I can tell you that the Remora 808 CP cartridge (a direct clone of the 808 circuit) works with both the BA6110 and BA662 clone. You just have to switch some pins:
BA662-------> YOCTO BA6110
pin 1 -------> pad 4
pin 3 -------> pad 1
pin 4 -------> pad 3 (and connect to GND)
Cocteau should be compatible, as the mods are not directly connected to the VCA.
JanneI
Hi all.
I have kacper's cocteau case and I have two complains..
First, the spdt switches don't really fit to the holes on the enclosure, way too tight.
Second, the silkscreen on the enclosure comes off just with a slight push with fingers/nails.
I have no complains on the previous kacper case, but this version is not cool. Anyone else building cocteau modded yocto recently? Did you notice this?
momo
JanneI wrote:
Hi all.
From this thread:
kacperpawluk wrote:
Hi! Some people reported problems with silkscreen quality. I anyone have this problem please write me (kacperpawluk@gmail.com or PM). I will repaint it and pay for postage. I changed silkscreen manufacturer. I get sample and quality is much much better now.
Paradigm X
my case hasnt even turned up yet... confused
hopefully its down to them being redone. not heard anything from the man tho...
goldplate
Hey ! Finally I began to build it.
Is it really important to distinguish the foil vs film polyester capacitors ? Is it good if I put mylar everywhere ? With a bit of twist it seems that this will fit.
Nice build doc indeed.
effegee
Foil is fine if you can get it to fit.
goldplate
I'm finishing it and begin to be very excited with what I hear, especially with the bass drum and hats. The construction is so well designed for such a big mod, congratulation !
About the build, it saves time to make all the connectors in once so here is a list of the lengths to cut for the cables :
Code:
Those are the minimal lengths of cables to cut so if you really want a lot of mobility with connectors in place you can add some more (but it's enough to open/extract Cocteau's PCB from Yocto's one).
SD Tune 1        2x 15 cm (shielded)
SD Tune 2        2x 14 cm (shielded)
BD Env           2x 10 cm
BD Tune          2x 8.5 cm
BD Env (CV)      TBDL
BD Tune (CV)     TBDL
BD Xtra Decay    2x 12 cm
SD Filter        2x 16 cm
Power            3x 7 cm (polarized)
RS-CL2 Trig      1x 13? cm
SD Decay         2x 17.5 cm (polarized)
LT Reverb        2x 8 cm
SD Filter (CV)   TBDL
SD Decay (CV)    TBDL
LT Decay         2x 15.5 cm
MT Reverb        2x 13 cm
MT Decay         2x 13.5 cm
HT Reverb        2x 8 cm
HT Decay         2x 15.5 cm
RS Tune 1        2x 11 cm
RS Filter        2x 14.5 cm
RS Tune 2        2x 11.5 cm
RS Tune 1 (CV)   TBDL
RS Tune 2 (CV)   TBDL
RS-CL2 Out       1x 21? cm
CP Reverb        2x 7.5 cm
CP Filter Sw     3x 10.5 cm (center pin "polarized")
CP Filter        1x 15 cm
CP Delay         2x 19.5 cm
CP Density       2x 19 cm
CB Filter        2x 11.5 cm
CB Tune 1        2x 17 cm (shielded)
CB Decay         2x 12.5 cm
CB Decay (CV)    TBDL
CB Tune 1 (CV)   TBDL
CB Tune 2        2x 17.5 cm
CB Tune 2 (CV)   TBDL
OH Filter        2x 9 cm
CH Filter        2x 11 cm
CH Decay         1x 9.5 cm
MA Out           1x 10? cm
MA Trig          1x 35? cm
Metal Tune       2x 17.5 cm
White Noise In   1x 13.5 cm
Accent           1x 2.5 cm
TOTAL   24AWG    670 cm
goldplate
Hey,
After a few uses, I found that the choices of potentiometers types and values could be improved, because some of them don't produce any change on half of their range, what is in my opinion unpleasant especially on the filters.
So because I love this project I proceed a lot of tests until finding the best types and values regarding the Alpha round knurled plastic shaft potentiometers available at Tayda. In the same time I added some improvements I found and sometimes this is somewhat mixed with the correction (which means they sometimes cannot be separated).
I'm happy to share the results:
BD Env extended lower & higher range and more precise higher range
- add a 470R resistor parallel with R4 or replace it by a 390R resistor
- replace VR32 by a C10K (anti-log) pot
BD Tune more precise higher range
- replace VR31 by a B100K (lin) pot if a progression focused on basses is wanted or by a C100K (anti-log) if a linear progression is preferred
SD Filter extended lower range, shortened higher range and more precise higher range
- replace VR34 by a C100K (anti-log) pot and add a 1K resistor in serie to remove the sound drop at maximal value
SD Snappy Decay extended lower & higher range and more precise lower range
- add a 15k resistor parallel with R7 or replace it by a 9.1K resistor
- replace VR35 by a A500K (log) pot
(untested*) SD Tune 2 more precise higher range
- replace VR37 by a B1M (lin) pot
(optional) LT, MT & HT Reverb extended lower range
- replace VR39, VR41 and VR43 by B250K (lin) pots if being able to go to almost drop out of reverb sound is wanted or by B200K (lin) pots if keeping a bit more precision in the higher range is preferred
(idea to be tested) LT, MT & HT Reverb maximally extended lower range and more precise higher range
- replace VR39, VR41 and VR43 by C100K pots and connect their pins 1 to ground (this would allow the sound to drop out at minimal value)
(experimental) LT & HT Decay extended lower range
- add 100nF film capacitors between VR39 and VR43’s pin 1 and ground
Note : those need the connectors’ cables to be soldered with the good polarity on the Yocto board : left pins of the connectors on Cocteau components’ side have to be connected to the North pin of the modded resistors
Remark : this mod could make loose the very long decay availability on the High Conga
(experimental) MT Decay extended lower range
- add a 27nF film capacitor between VR41’s pin 1 and ground
Note : this needs the connector’s cables to be soldered with the good polarity on the Yocto board : left pin of the connector on Cocteau components’ side has to be connected to the North pin of the modded resistor
RS Tune 1 more precise higher range
- replace VR44 by a B1M (lin) pot
(untested*) RS Tune 2 more precise higher range
- replace VR46 by a C10K (anti-log) pot
CP Reverb maximally extended lower range and more precise higher range
- replace VR47 by a C100K (anti-log) pot and connect its pin 1 to ground
CP Filter extended lower & higher range and more precise higher range
- replace VR48 by a C100K (anti-log) pot
- add a 62R resistor in parallel with R25 or replace it by a 47R
(optional) CP Density shortened lower range (no more drop out of the noise part of the clap sound in the lower range)
- add a 3.6K resistor in serie with VR49 (in e.g. in using the CP Extended Density dual linked pads to cut at VR49 South-East)
(untested*) CB Filter more precise higher range
- replace VR51 by a C10K (anti-log) pot
(optional) CB Long Decay extended higher range
- replace VR52 by a B2M (lin) pot
CB Short Decay shortened higher range and more precise lower range
- replace VR53 by a A1M (log) pot (a bit of decay length at max value will be lost but it’s really an ultra tiny bit)
Metal Tune shortened lower and extended higher range (no more drop out of the tune part of the sound in the lower range)
- replace VR58 by a C100K (anti-log) pot
- short R71
- disconnect VR58's pin 1 from ground and connect it to ground via a 10k resistor
OH & CH Filter more precise higher range
- replace VR55 and VR56 by C100K (anti-log) pots
CH Decay extended lower range
- add a 15K resistor in parallel with R30 or replace it by a 10K resistor
*very likely to be effective
Note: some Cocteau mods without switch and aiming to make get the 808 original sound on extreme values of pots are a few times changed and hence this will loose the easiness/guarantee to find the original sound (but it should still be somewhere in between).
For the pots, I'm totally sure this will be better for anyone, but about the resistors it is not sure any Yocteau would get the same results (as I have an all-metal-film-resistors Yocto) so maybe this will be needed to find the good value himself.
About the pots which are out of stock at Tayda (like the C10K), they are expecting a restock within this month. cool
Effegee, even if I will need to desolder a lot of $0.67 pots, thank you again for making this dream comes true, because it's here in front of me and sounding f***ing good. we're not worthy
Next step: discovering some cymbal and hats mods for the remaining empty slots. waah
