Midi2CV no sync output
MUFF WIGGLER Forum Index -> Hexinverter Electronique
Author Midi2CV no sync output
flyingMono
Hello,
I built this module a long time ago, before I had a midi controller. Or rather, after my midi controller broke and haven't replaced it yet. Finally replaced it and am now trying to set it up properly. Everything works except the sync output. The LED doesn't light up, I'm pretty sure its installed correctly. I installed the others correctly so by default this one should be correct too. hihi If it is installed incorrectly, would it inhibit the sync pulse from making it to the output jack?
synthetek
Are you sending a midi clock in?
flyingMono
Yes, it's coming from Live and Sync is selected in the preferences.
flyingMono
Figured it out. My midi keyboard In wasn't passing the sync signal, which makes sense because there isn't a thru port on it. ...duh d'oh!
