modules with 3.5mm TRS MIDI jacks
kay_k
Post by kay_k » Sun Aug 06, 2017 2:50 pm
help me to make the ultimate list!
DEZ 2019:
Someone compiled this beautiful website:
https://minimidi.world
So I think I'll probably stop adding to the list below.
[EDIT November 2019: I am very sorry, I confused type A and type B, now corrected]
Type B; Polarity Arturia: Ring: Data; Tipp Vcc
Type A; Polarity Korg: Tip: Data; Ring Vcc (NOW THE MIDI 2.0 STANDARD!)
Polarity non-TRS (a.k.a. MFB): Sleeve & Tip
ALM Pamela's New Workout with Expander (Output; polarity internally swap-able)
MFB Nanozwerg Pro (Input; Polarity NON-TRS!!)
MFB SER-1 Pro (Output; Polarity probably NON-TRS too)
LPZW.modules WK3 (Input/Thru; Polarity auto/switchable)
LPZW.modules SCHLEUßIG (Input; Polarity auto)
LPZW.modules TRAM8(Input; Polarity auto)
Erica Synths Drum Sequencer (Input; unknown)
Five12 Vector (I/O; Arturia)
SDS Digital WifiMidi (Output; Korg-ish)
SDS SDS_VCO (Input behind panel; User configurable))
SDS Reflex LiveLoop (Input behind panel; user switchable)
SSF Bantam (Input; unknown)
Soulsby AT-Arp (Input; unknown)
Malekko SYNC (I/O/Thru; Arturia)
1010 Music MX4 (Input/Thru; polarity Arturia)
1010 Music fxbox/bitbox (Input; polarity Arturia)
1010 Music Toolbox (I/O; polarity Arturia)
1010 Music MOK Waverazor (In; polarity Arturia)
ADDAC System ADDAC221 (I/O; Polarity Korg)
ADDAC System ADDAC222 (I/O; Polarity Korg)
Pittsburgh Modular Liveforms SV-1 (Input; Arturia)
Entrospec iungo (I/O; Polarity Korg - 2.5mm jacks!!! why, oh why? )
Flame Quad-CV-Recorder (Input; Arturia)
Flame 4Vox new version (Input; Arturia)
Flame Filterbank (Input; Arturia)
Twisted Electrons Crazy8 Beats (i/o unknown) - also standalone
Pittsburgh Modular Lifeforms Voltage Lab(Input; ?)
Pittsburgh Modular Sequence Designer 128 (I/O; Arturia)
Zetaohm FLXS1 (I/O; Korg)
VPME.de trig31 (Out Arturia)
Dreadbox Lil' Erebus (In, Korg?)
Analog Solutions Treadstone Eurorack (In, unknown)
mxmxmx C2M (In/Out user configurable)
Michigan Synthworks MBrane (MI YARNS) (I/O unknown)
Shakmat Modular Clock O' Pawn (In: unkown)
Futureretro MIDI BUS expander for Trax! (I/O Arturia)
Supercritical Synthesizers Demon Core Expander (i/o auto-crossover in & user selectable out)
Westlicht Per|former (i/o polarity Korg)
XOXO MIDIXO (Model 92½) (i/o polarity configurable)
Polyend Poly 2 (i/o polarity Arturia)
Dreadbox Cases (Input ...)
Intellijel Palette 4.5U Cases (i/o polarity ?)
Non Modular:
- Make Noise 0-Coast (In; Polarity Korg)
- Korg Electribe 2/Sampler (I/O; Polarity Korg)
- Korg SQ-1 (Ou; Polarity Korg)
- Arturia Beatstep (Out) & BS Pro (I/O; Polarity Arturia)
- Novation Launchpad Pro (I/O; Polarity Arturia?)
- Novation Circuit (I/O; Polarity Arturia?)
- Novation Circuit Mono Station (I/O & Thru; Polarity Arturia?)
- Faderfox SC4 (I/O; Arturia?)
- Twisted Electrons Acid8 (I/O unknown)
- Twisted Electrons AY3 (Input unknown)
- Twisted Electrons Crazy8 (I/O unknown)
- Twisted Electrons hapiNes(In: unknown)
- Twisted Electrons TherapSid MkII(I/O: unknown)
- IK Multimedia Controllers, Midi Interfaces, UNO Drum&Synth (probably Korg/Type A)
- Analog Solutions Treadstone(In, unknown)
- Teenage Engineering OP-Z with oplab (I/O; polarity Korg??)
- Teenage Engineering Pocket Modular 16 (Output: polarity Korg)
- Elektron Model:Samples (I/O polarity ?)
- Critter And Guitari Organelle mk2 (I/O polarity Arturia)
- Empress Effects Zoia (I/O polarity ?)
- M-Audio Air Interface Series (I/O Type ?)
DIN-TRS Mapping according to MIDI.org
A fun DIY project for the cold winter evenings to do with the whole family:
https://www.midi.org/articles-old/updat ... din-cables
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Sun Aug 06, 2017 4:49 pm
There are also the ADDAC221 10x9 Channel CV to CC MIDI System, and the ADDAC222 4x6 Voices 1V/Octave to MIDI Notes that use TRS MIDI jacks which apparently use the Korg standard.
-James
kay_k
Post by kay_k » Mon Aug 07, 2017 5:10 am
ersatzplanet wrote:There are also the ADDAC221 10x9 Channel CV to CC MIDI System, and the ADDAC222 4x6 Voices 1V/Octave to MIDI Notes that use TRS MIDI jacks which apparently use the Korg standard.
added to the list. Thanks!
indigoid
Post by indigoid » Tue Aug 08, 2017 6:03 am
Pittsburgh/Lifeforms SV-1 also, I believe
Not sure which way it's connected
Zap him again! ZAP THE SONOFABITCH AGAIN!
kay_k
Post by kay_k » Tue Aug 08, 2017 8:54 am
indigoid wrote:Pittsburgh/Lifeforms SV-1 also, I believe
thanks!
batch
Collector of fine modules
Post by batch » Tue Aug 08, 2017 3:42 pm
SV-1 works with BSP
Monday Night Modular - a weekly virtual meetup @ 8pm PT
kay_k
Post by kay_k » Tue Aug 08, 2017 3:44 pm
Armstrb wrote:SV-1 works with BSP
:tu:
ADDAC System
Post by ADDAC System » Tue Aug 08, 2017 6:20 pm
Hi! Can you please make a correction? We are called ADDAC System and we have two modules that use the Korg standard, those are the ADDAC221 and ADDAC222. Thanks!
Questions? Assistance? Hit me up via PM or send us an email!
ADDAC System | [www.addacsystem.com]
indigoid
Post by indigoid » Tue Aug 08, 2017 6:39 pm
Sounds like a passive module to convert between the various formats (and DIN) might be worth doing. Could design it so that its PCB could fit in a small standalone case also, like Mutable Instruments CVPal
An SQ-1 is in my future so maybe this is worth doing. It would be a fairly easy piece of Eagle design work
kay_k
Post by kay_k » Wed Aug 09, 2017 2:43 am
Done! Thanks for the input!
kay_k
Post by kay_k » Wed Aug 09, 2017 2:45 am
indigoid wrote:Sounds like a passive module to convert between the various formats (and DIN) might be worth doing. Could design it so that its PCB could fit in a small standalone case also, like Mutable Instruments CVPal
our WK3 is basically the active version of what you ask for.
As for the passive thing. I just had an idea this morning while sitting in the train to work - how about a little I/O plug in between. Like the Airtenuators or the 0HP stuff? should be somewhere in the 3-10€ area. depending on how many are produced. it could get waaaay lower but then it would need to become a made-in-china mass product.
I also think about making those to midi standard: LINK
(I bought one and it is not)
Roy72
Post by Roy72 » Wed Aug 09, 2017 4:27 am
Modcan touch sequencer. Not sure which standard, but it works with the BSP without messing around
kay_k
Post by kay_k » Wed Aug 09, 2017 4:43 am
Roy72 wrote:Modcan touch sequencer. Not sure which standard, but it works with the BSP without messing around
https://www.modulargrid.net/e/modcan-touch-sequencer
is this really MIDI .. their video says 24ppq clock, the panel says sync.
Roy72
Post by Roy72 » Wed Aug 09, 2017 5:19 am
Sorry, got the two confused. Carry on...
sneak-thief
Post by sneak-thief » Wed Aug 09, 2017 5:20 am
Meris Mercury7 reverb pedal IO
http://involucija.org - post-industrial euphoric deprogramming. LP coming soon on a+w.
kay_k
Post by kay_k » Wed Aug 09, 2017 6:10 am
sneak-thief wrote:Meris Mercury7 reverb pedal IO
ooh, that is an interesting one. do you have it?
It is not only quarter inch instead of 3.5mm it also is MIDI I/O & CV/Footpedal in one jack. I have not found out how that works from the pics and manual.
sneak-thief
Post by sneak-thief » Wed Aug 09, 2017 8:42 am
Yes, the Mercury7 uses 1/4" but seeing as 3.5mm adapters are trivial, I thought I would add it here.
Yes, I have one and it's can get the closest to a 224 I've heard so far. IMHO all the other fancy 224 plugins and the BAM have ringing artifacts that sound quite different from the original.
There's a 1/4" jack that can be switched between MIDI I/O, expression pedal input, tap tempo, and preset switcher.
Here's the full manual:
https://www.meris.us/wp-content/uploads ... ual-v2.pdf
Paranormal Patroler
Post by Paranormal Patroler » Wed Aug 09, 2017 12:10 pm
Iungo module is CV-to-MIDI, uses Korg specification. Also upcoming Delptronics will be changeable via software.
windspirit
Post by windspirit » Wed Aug 09, 2017 12:34 pm
We are actually working on something but if someone beats us to it I wont be that upset. Its really just something that should exist.
Remember when all the big synth companies got together and worked out a UNIVERSAL solution to transmitting data between devices? :doh:
kay_k
Post by kay_k » Wed Aug 09, 2017 1:08 pm
sneak-thief wrote:Yes, the Mercury7 uses 1/4" but seeing as 3.5mm adapters are trivial, I thought I would add it here.
still do not understand how it is an I/O in one jack. :/
how do you connect it? and to what?
kay_k
Post by kay_k » Wed Aug 09, 2017 1:10 pm
sorry, brain patched faulty.
why can't I delete my own posts?
kay_k
Post by kay_k » Wed Aug 09, 2017 1:17 pm
Paranormal Patroler wrote:Iungo module is CV-to-MIDI, uses Korg specification. Also upcoming Delptronics will be changeable via software.
added ..
kay_k
Post by kay_k » Thu Aug 10, 2017 5:17 am
So I just had one of those ideas you get when you have something important to do but you rather let your head drift somewhere else:
it's just two Thonk PJ3410 soldered together as passive gender changer. Easy as f**k
Paranormal Patroler
Post by Paranormal Patroler » Thu Aug 10, 2017 5:20 am
The solution is easy, which means that the problem is stupid to begin with. ~sigh~
kay_k
Post by kay_k » Thu Aug 10, 2017 6:01 am
Paranormal Patroler wrote:The solution is easy, which means that the problem is stupid to begin with. ~sigh~
:deadbanana:
absolutely. someone has fucked this up for us. let's find him!
:hyper:
