F6 random quantized cv - Y INPUT not working
Author F6 random quantized cv - Y INPUT not working
KvotheKingkiller
Having trouble getting the Y input to do anything on this algo.
I do have the sequenced locked, on the negative side. Tried just routing a maths dc offset channel to manually sweep till it would change something, but nothing happened. Say the input led go red, so assuming the cv I sent definitely crossed the 1v threshold mentioned in the manual.
I also tried one of the maths EOC triggers. No joy.
What am I doing wrong? Any help appreciated. Thanks.
BarneyRubble
Can't comment on if you're doing wrong or right but I get the same thing when the Z control is fully left (blue light).
But with Z control fully right (red light) a pulse into Y input does change the sequence so I'm guessing this is by design.
KvotheKingkiller
Thanks for the info, helps with troubleshooting, forgot to try the red side locked. Will give that a shot.
Although it seems like it would be nice if bit flipping functionality worked on either locked side.
KvotheKingkiller
bump, just want to know if this is by design.
Yes. The Y input causes the bit to be flipped on every clock. But for locked negative Z, the bit is always being flipped on every clock anyway.
