curiosity: svco placeholder for expansion
Pav
Post by Pav » Tue Aug 22, 2017 5:53 am
hi,
svco a&b build guides tells you to leave out resistors for expansion port.
(not to be confused with octave daughter board of svco-b )
Is this ever used with another oakley module..or just available to use if diying?
The schematic shows a saw out, a cv2 in, and a dtune and Lin CV ..which I assume are inputs.
pins 2 and 4 am i understanding the schematic symbols correctly ..ground and 0V ? Is this in keeping with your recommended practice of keeping panel and pcb grounds separate ?
..as i say more curiosity than need for build.
rgds Pav
Synthbuilder
Re: curiosity: svco placeholder for expansion
Post by Synthbuilder » Tue Aug 22, 2017 8:50 am
Pav wrote:Is this ever used with another Oakley module..or just available to use if diying?
You could certainly DIY something to it, but the main reason was to make a 2U wide version, the SVCO-C. This would have a rotary octave switch, linear detune control and CV input, triangle and sinewave output, and a wide range coarse frequency control.
Due to various reasons the module never made it to fruition.
Yes, both panel ground and module 0V are on that header.
Tony
