Disting mk3 problem
Author Disting mk3 problem
pynchy
I'm having an issue with my mk3, when I power on the start up led sequence will run but then all ​the led​s​ stay fully on or maybe flashing at audio rate. If I power on but hold the knobs it will go to the upper two led flashing but with no way to exit this.​ I tried updating the firmware to latest release, this process runs fine and confirms firmware has updated but I reboot the same thing happens... all the leds stay lit.​
Any help would be appreciated.
I have sent this to expert sleepers as well but it hought i might as well try here also.
Replied to your email.
wiwwah
I've also had this happen with my MK3 today. Was all fine yesterday but when I turned it on all LED's were flashing. Tried another firmware update which worked perfect then did the same after a reboot. Is there a fix for this?
Only in hardware. Email me.
wiwwah
Done smile
