the Reverse Question: Video Modules for audio rigs
Author the Reverse Question: Video Modules for audio rigs
acgenerator
I see a lot of threads talking about getting typical Eurorack to work in the video space, I'm a bit more interested in the reverse.
Right now, I need to focus on the audio space but I have an interest in perhaps dabbling in video down the line. Are there modules from the video brands that will serve me well in audio so that when the time comes for video, I'll already have a fair number of support modules? (I know I will need to by core Video modules at that time).
E.G. I have LZX Voltage Bridge (Visionary Series) which I use for other scaling purposes.
Are there other modules I should look at? Some of the ones that look like they may have promise:
BSO - Video Scanner
LZX - Arch
LZX - Video Logic (upgrade from a slower logic)
LZX - Flip Lops (upgrade from a slower switch)
nerdware
Sensory Translator will work well for both audio and video.
Cat-A-Tonic
If you're just doing drones, then a lot of video modules will do audio just fine.
No V/oct though, so melodies would be tedious.
As far as compatibility when patching with other Eurorack,
you may have to boost some signals.
Thresholds for gates are often higher on modules designed for audio.
acgenerator
Not a problem here. I have and use the LZX Voltage Bridge for Vx5 and V/5 scaling CV in an Audio only rig as it is.
