Ableton Midi-Clock-Sync with Disting possible?
Author Ableton Midi-Clock-Sync with Disting possible?
mojodrums
Hello,
I'm planning my future setup.
i want to sync Ableton and my drum machine via a tight Midi Clock.
Since I already own the ES40+8CV and am thinking about buying a Disting...
I saw that Midi Clock is possible on the Disting but it seems that I'd need a workaround generating an Audio Clock Pulse signal in Ableton and route it to the Distings input. So could not send notes then, right?
Would an 8MD be a much better and versatile option than the (cheaper) DIY MIDI Breakout for the Disting or can they do the same thing?
Thanks,
Tobi
If you already have the ES-40, an ESX-8MD is the no-brainer option.
