Any Mac Music Plugins that do Rings
Author Any Mac Music Plugins that do Rings
scottmoon
I'm looking for something that can do the string and resonator sounds of Mutable Rings. Suggestions would be helpful. thumbs up
nostalghia
Haven't tried it, but this has a free demo download and seems interesting.
Stillwell Audio Tinman Intelligent Resonator
Also found this one (has a demo to try first as well): Sinevibes Hexonator
What plugin format do you need? AU for Logic? VST?
Looking for something that you feed with your choice of audio input? Or that can self generate sound (only needs clock)?
scottmoon
Thanks, I'll check these out later. I use Logic and even something that works in Reaktor would work.
lohacker
For Reaktor check out Prism
MalteSteiner
Logic? Then you already have Sculpture, the buildin physical modeling synth
there's a bunch of resonators in the reaktor user library. i don't own rings so can't compare.
https://www.native-instruments.com/en/reaktor-community/reaktor-user-l ibrary/all/all/all/all/resonator/latest/1/all/?q=resonator&t=userlib
scottmoon
This sounds great and has a nice interface and feature set. Not cheap but could be worth it.
Doh. I forgot I've used it before. Has that sucky Apple synth interface but sounds good if you can figure everything out.
I'll have to go through some of these. They don't always have audio previews so it's a bit hit and miss. I downloaded Resonator by_Colugo and I'll give it a try.
Thanks everybody. applause thumbs up
ccastellanossf
If you are Max/MSP savvy you can always build your own. :-)
There is also a CNMAT external called resonators~:
http://cnmat.berkeley.edu/patch/4019
