Matrix mixing
Author Matrix mixing
lionelfischer
I'm thinking of getting the doepfer matrix mixer to use for color mixing with lasers. i figured if i had one cool patch going, i could have it going thru the matrix mixer before going into the laser, and i could quickly change and shift things around and revert back to the original one etc with ease that way. Are there other matrix mixers, or methods of patching i should consider before pulling the trigger on the doepfer matrix?
adam
the wmd ssm allows you to switch between preset - what do you call them, things, you can patch up a bunch of different routings then switch
mutable frames is also like this
4ms vca matrix another one to check out, has buttons so you can turn certain routings on or off
lionelfischer
ericas sequel to theirs should check all the boxes, attenuation etc
