200e Preset Bus Isolator Available
Author 200e Preset Bus Isolator Available
studio.h
Hi folks, I now have a Bus Isolator available for the 200e:
This device allows you to connect multiple powered busboards together on the same preset bus.
For example, you can connect two separate, powered, 18-wls cases together with this isolator installed on the cable between them. A single preset manager in one of the cases will see all the modules in both cases.
For those wishing to expand beyond 24-wls, this isolator will provide two benefits:
1) It will permit a second brick to be used to bring in more power to supply the additional modules.
2) It will stabilize the preset bus. We have found that long power and ground lines (even non e clone modules) can lead to preset lockups. The isolator divides the system into multiple, smaller powered systems, and solves that problem.
The devices are $65 each, and available immediately. Please send an email to dougcl@studiohsoftware.com for details.
Thanks,
Doug
Minimoog56
Doug - are you offering two of these designs or just one. You previously came up with the solution for the 285e/258e which was bus support for presets for more than 24 modules. Is this a different offering - allowing for multiple power plus bus assist or is this the same unit improved.
studio.h
Both devices are offered.
The repeater is used on boat cables within a powered system (like a 24-wls). The isolator is used on cables between powered systems (like between two 18-wls cabinets).
You can have both at the same time: repeaters on the passive boat connections and isolators between the powered boats.
Doug
