Deerhorn Organ w. intersections
home of post-70s electronics
Moderators: Kent, bartlebooth
prscrptn
Post by prscrptn » Sat Sep 09, 2017 9:38 pm
The design of the Deerhorn circuit has evolved much since it was first created to answer Clara Rockmore's original complaint with the Theremin: "Can there be more than one pitch?". Lev Theremin responded that one would need more than two arms, but the Deerhorn makes this possible by extracting gestural information from the radio fields and using it to control pitch and envelope. The current unit contains three of these antenna-synthesizer modules, and adds two extra, highly useful modules known as intersections.
An intersection module simply samples one deerhorn's antenna voltage at impulses provided by another module. It is a sample and hold, triggered by changes in gestural direction. Since there are three modules, there are six permutations, doubled because each module reports changes in both directions; there are twelve new outputs, plus four special ones that sample in random steps. Each deerhorn module emits a different light— red, orange, and yellow— which also color-codes the intersection bananas to show which module is being sampled.
The Deerhorn modules are color coded. An [orange banana] reports its primary product: a control voltage representing the hand's distance from antenna. The impulses utilized in intersections, are also available as [red bananas]. These are like two complimentary square waves that flip when the hand changes direction.
The base tone of deerhorn is a simple two tone straight bellow. That's as your hand moves in towards the antenna and back out again. You must always tune the response first, so that the two leds cross each other at a comfortable range from the antenna. Fine tuning is done with the top knob.
The bottom cluster of controls deal with the synthesizer frequencies. The bottom knob sets the base pitch of both oscillators. The next two knobs are associated with the [purple bananas]: they are FM tuning knobs. The switch on the stub of the deerhorn orients the stereo position of the oscillators. In middle position, it turns them off (for the stereo auxiliary inputs). The white bananas output the same stereo sound which is output the main output, but in single tracks so it can be used as separate modulation sources.
For coarse tuning of the antenna, two trimmer capacitors lie beneath every deerhorn module. They are well-tuned upon shipping, but may always be accessed via a face-port with small slotted screwdriver.
windspirit
Post by windspirit » Sun Sep 10, 2017 6:02 pm
Yeah I saw the video for this,having the option to modulate the pitch for each osc using gestures is great. I usually use the deerhorn on the pb for control since alternating between two oscillators can eb kind of boring without a lot of modulation. Definitely interested in hearing more.
wednesdayayay
Post by wednesdayayay » Wed Sep 13, 2017 1:18 pm
I am liking those intersections I bet it would be fun to incorporate into a larger CL system!
sh is the sound of data
bobo is the gesture
PB
aethersprite
Wiggling with Expedience
Post by aethersprite » Wed Sep 13, 2017 3:55 pm
Oh man I've been wanting the DH organ forever and I think this intersections puts me over the edge :ripbanana:
knows
Post by knows » Thu Sep 14, 2017 3:29 pm
Does anyone know if the intersection is already present in the deerhorn or if it is an additional circuit added?
jimmie
Post by jimmie » Sat Sep 16, 2017 11:34 pm
yeah, I wonder if newly made plumbutter has the intersection.
wednesdayayay
Post by wednesdayayay » Sun Sep 17, 2017 4:36 am
since the intersection is crossing multiple deerhorn together I would assume no on the plumbutter
maybe if you had a double plumbutter? but even then that is 2 deerhorn and not 3
I wouldn't hold your breath about getting it on other instruments
it would be neat though
bobo is the gesture
PB
jimmie
Post by jimmie » Sun Sep 17, 2017 8:00 am
Do you know wheather the dual butter is just 2 PBs on one long wood base (which is my guess) or something else - like audio output is one combined, DC plug is also single rather than two? If dual model actually takes advantage of dualness (external input is wired differently and so on) it's so great, I'd really want one in the future if I can ever afford.
thresholdpeople
Post by thresholdpeople » Wed Oct 25, 2017 5:32 am
Nice addition to the dearhorns. I don't know how I feel about the jacks and controls being on the antennas, as I always played my dearhorn kind of close to them.
chrisdermo
Post by chrisdermo » Fri Nov 17, 2017 9:36 am
would really love to hear one of these used more extensively if anyone has one? How do the aux inputs work? Do they replace the oscillators or simply become a modulation source accessible by a banana socket?
jimmie
Post by jimmie » Sat Nov 18, 2017 1:15 pm
I guess aux inputs are the same of PB - replace internal oscillator audio with the external signal. And you can control only the volume of the signal. I don't have the device so I may be wrong tho.
I'm interested in how oscillators' pans are set in stereo. My gut feeling is all 3 horns are full hard panned to left and right, tho, I so hope if the center horn is center, side horns are slightly offset from hard right/left etc...
thresholdpeople
Post by thresholdpeople » Sat Nov 18, 2017 5:16 pm
At least on the older one, the panning was caused by moving your hand toward and away from the antennae. Forward was one channel, away was the other. All three horns were like that.
chrisdermo
Post by chrisdermo » Sat Nov 18, 2017 5:45 pm
I think I read somewhere you can choose per deerhorn whether forward is left and backwards is right or vice versa for this new one.
chrisdermo
Post by chrisdermo » Tue Nov 21, 2017 5:49 am
Mr. Smog has one of the new ones, and uploaded a vid of it yesterday :yay:
[video][/[/video]
Video is embedding but won't play for me....
link:
Return to “Ciat-Lonbarde”
