FH1 & Squarp Pyramid Fast Triggers not working
Author FH1 & Squarp Pyramid Fast Triggers not working
Tropic Al
If I send fast triggers from the Pyramid using the best repeat at anything above 1/32 then it seems like the FH1 is smoothing the individual triggers into one long signal.
I know its not a fault with the Pyramid because the fast triggers work absolutely fine with midi.
OS - do you still have the Pyramid and are you able to test this?
The FH-1 triggers are fixed length, so if you trigger them fast enough they'll overlap.
Is that what's happening?
Tropic Al
I imagine that's whats happening.
Is it possible to make them shorter?
Not in the current firmware.
I'll put it on the to-do list.
Tropic Al
Thanks! Look forward to it.
