power solution: old lab supply instead of PA-20/30 ?
Author power solution: old lab supply instead of PA-20/30 ?
mmeixner
Yes, power question again.
I'm just planning my Oakley system. About 20 modules are already built or will be finished soon. And more to come, obviously :-)
The whole system will live in a shelf, so this is not a movable solution, just for context.
My planning is to use two Oakley PSUs feeding into Hinton busbars. Today I stumbled over my former lab supply (I bought a better one recently):
I would like to use this to feed the Oakley PSUs instead of PA-20/30s. Of course I could power the whole system just from this one, but I think it would be safer to distribute power into two independently switchable branches; moreover I think the Oakley PSUs are more refined power sources. The Oakley PSUs will not care, if they are fed AC or DC.
Any thoughts about this plan? What would be a proper voltage to feed into the Oakley PSUs? 18V?
[edited: growing number of modules]
Synthbuilder
Using a bench supply is certainly one way to do it - but it's possibly a little complicated and bulky. One thing to note is that using DC to supply the Oakley PSU will create a large power-on surge current. You may wish to reduce the smoothing capacitors to something like 100uF.
I think you'll need about +/-20V to guarantee a stable +/-15V output under all loads. You'll need 3V to keep the LM723 happy, 0.6V across the current limiting resistor and around 1V across the rectifier diodes.
The Hinton bus bars, or something similar, are a great idea for any large system. The resistance of the power distribution lines should be as low as possible. Graham also makes some very nice power supply systems too.
Tony
mmeixner
Tony
Thanks for remarks and hints!
I wouldn't have thought about reducing capacity - thanks!
It's just, that this PSU is here without other uses, so I might just use it for this for a while :-)
I asked Graham about his PSUs too, but since my shelf does have some non-orthodox measurements (335x335 mm per department), he told me, that would be not a good idea, his PSUs being 19"-ish ...
I guess I will build and see what works.
Thanks again!
