Behringer Us 600 - Exp Input
Author Behringer Us 600 - Exp Input
researchclub
Is possible to put a sequencer to change the pitch using the exp input?
JayEm
quick glance at the manual and i think you could however it probably won't be totally predictable. it requires a trs jack on the input, most cv sequencers will just ouput a mono signal. its also a digital pedal, and i doubt the input is going to track all that well if you do plug in (insert cable might work)
researchclub
Thanks a lot for the quick answer!
