capacitor charge
Author capacitor charge
s'mores
I wanted to try out some big caps (physical size and voltage rating, not capacitance - i.e. a 1NF 600V orange drop) in a filter design. As far as I understand, I don't have to worry about dying from accidentally shorting out a cap in a synth circuit because the voltage across the cap in use is what matters, not its rated voltage. Any other potential downsides to using these caps or should I just listen to my ears?
Nantonos
Exactly. You are not going to get explosions or welded screwdrivers from a film cap used on ±12v. Not like huge electrolytics in power amps or high-voltage charged caps in valve/tube circuits.
s'mores
update: they all sounded like shit anyways compared to mica / C0G. was worth a shot...
s'mores
those 15mm lead spaced Wimas sure did look sexy though!
tojpeters
I have used orange drops in the Serge '73 filter on several occasions with very good results
s'mores
Never actually tried the orange drops, only the Wimas and some Panasonic film caps --- maybe I should
