Will someone explain how the Roland d-50 works?
Author Will someone explain how the Roland d-50 works?
oneano
I can’t figure out what is going on in a d50.
Are those sampled envelopes?
Are there pcm samples?
Are the waveforms sampled?
I think each voice has 4 partials and a partial is a sample or oscillator is this right?
sduck
Yes, PCM samples; no, regular envelopes.
It's been a llloooonnnggg time since I owned a D-50, so this will have to do (from me)
commodorejohn
Not sure what this means; the envelopes are full-fledged multi-stage digital envelope generators whether they're applied to samples or not.
There are both sampled and synthesized waveforms in the D-50. The samples tend to be short attack phases, though some of them are looped. The synthesized waveforms are limited to sawtooth and pulse, with a resonant lowpass filter which the samples do not have.
That's "DUAL" mode, which is generally the way it's used, yes. In "WHOLE" or "SPLIT" mode, two-partial voices are used instead and the polyphony is doubled.
Happyanimal
Yes- first 50 or so are short/attack samples, the rest are looped sustained samples with some incorporating the attack samples in a loop.
