Patching an XOR Gate?
Author Patching an XOR Gate?
hinterlands303
I've figured out how to patch or, and, nor, and nand gates with a combination of mixers, vcas, inverters, and offsets, but are there any good ways to patch up an xor gate without a dedicated logic module?
Would this work?
Gate A into mixer channel 1
Gate B into inverter into mixer channel 2
Mixer out to rectifier.
Rectifier out = XOR gate
cptnal
Is this an academic exercise or do you have a pathological dislike of logic modules?
mojopin
check out this thread:
http://www.muffwiggler.com/forum/viewtopic.php?t=48299&sid=56b00cf7978 3c1287fb5263fa7222efb
hinterlands303
Thanks! The search function in the forum isn't working for me but I should have just done a google site search.
hinterlands303
Part of it is just trying to get my brain around it, and the other part is deciding if I really need my rarely used logic module if I can approximate the functions other ways.
cptnal
Interested because I just bought a Doepfer and I'm wondering, "what else can I do with this other than the obvious?" I'll be watching this thread for any of those gems that pop up in unexpected places.
mskala
If your logic levels are positive and negative (instead of positive and zero), then any four-quadrant multiplier or "ring modulator" that works at DC will do the XNOR function. Add negative offsets on input to convert positive/zero logic levels to positive/negative; invert one input or output to make it XOR instead of XNOR; and use a comparator on output to convert back to positive/zero logic if you like.
cornutt
Another way of getting an XOR, if you have two signals at logic levels:
1. Electrically invert one of them, e.g., if it's +5V, it becomes -5V.
2. Add them. A simple passive adder (two resistors) will do.
3. Run the output of that through a full-wave rectifier.
hinterlands303
This is a much more elegant way of noting the patch I had in my first post- much easier to follow. I tried it and it works great. Plus if you're a in Euro the WMD/SSF Toolbox has all of these functions so it's super easy to patch up.
frijitz
http://www.electro-music.com/forum/topic-21851.html&postorder=asc
https://www.youtube.com/watch?v=riqagh0gX-Y
Ian
