Juno66 reset settings? Strange sounds, tuning etc
MUFF WIGGLER Forum Index -> Tubbutec
Author Juno66 reset settings? Strange sounds, tuning etc
ramos808
Hi all,
Got the JU66 installed yesterday. Is there a way to reset settings all settings?
It's doing all sorts of different sounds like extra LFO's, wonky sounds and detuned.
Have tried factory reset but it doesn't work.
I'm guessing theres a setting or 2 turned on in the config? Maybe something is set via midi?
It's for a Juno-6, will record sound tonight if I can't turn the settings off and get it back to OEM.
How can you tell what version of firmware is installed?
tubbutec
Hi ramos,
what you describe is often the result of a short or open trace due to the socket installation. I recommend to check all connections carefully.
ramos808
tubbutec wrote:
Hi ramos,
Thanks, turn out the bender sliders settings are activated even without touching the bender.
My tech is looking at why
juno72
I do have issue with the benders, too. Interested to hear if you could solve it.
