Shallowest power supply?
Author Shallowest power supply?
exportexport
Hey there,
i think there's already a topic on this but my search function does not work for some reason.
So what is the flatest power supply in Eurorack? DIY would be awesome so that i can install the power switch wherever i want. The thing is: my case is a 6U 104HP made of wood and it's only 60mm deep from the panel top to the inner bottom. A Doepfer module is already 40mm deep. So it needs to be really shallow.
Thanks in advance! Guinness ftw!
Armstrb
Malekko?
mirth23
Tiptop ยตZeus with flying bus cables is a common solution in your situation, but it does eat some hp.
As a general note, thru-hole DIY and Doepfer are often not friendly with shallow cases due to bulk and layout.
