Damn. DFAM.
banalytic
Post by banalytic » Tue Dec 18, 2018 10:42 pm
really love my dfam!
now I want to build a "utility"-case around the dfam in a moog 60 case.
I re-arange my setup at the moment and have still some modules out of use...
pamela and Basimilus Iteritas Alter would be new...
any recommentations or hints?
banalytic
Post by banalytic » Thu Dec 27, 2018 8:06 pm
no one? :hmm:
JakoGreyshire
Post by JakoGreyshire » Thu Dec 27, 2018 9:23 pm
Attenuverters.... I would recommend Mutable Instruments Shades..
Pamela will do looping random stuff and a lot of things... I think I have some older videos of just the DFAM and Pamela banging it out... However, Pam's doesn't do bipolar CV.
With shades you can set up the knobs so that when you turn the top knob all the other outputs change. I'm a big fan of moving one thing and a bunch of things change.. I'm also a big fan of feedback loops, so attenuverters can be used for that too...
With all that said, It's hard to ignore Maths from Make Noise... Two attenuverters, and two channels of Attach Decay EGs... There's so much to do with Maths...
If this rack is the space you have to work with, I would suggest getting rid of the Pittsburg mixer for a smaller mixer. I have a 3HP Malekko Mix 4 and a 3HP Erica synths RND random module that takes up 6HP total and that is a lot of utility goodness in 6HP!! ( I also have a video I made explaining the outputs on Erica's RND module)
I don't have one or owned one but I'm sure a voltage block would do for an excellent companion module...
You might want to fully exploit Pamela's New Workout by self patching it... Take on of its outputs carefully plan to modulate itself in one of the inputs... There is so much there by doing that.... Pamela will do a lot.. I still have to dig deeper with it.
So to recap, I recommend:
Erica Synths RND
Mutable instruments Shades
Malekko Mix 4
Make Noise Maths
There are lots of choices and these ones I know personally. Keep patching and thinking about what you want to make happen... Have fun with your modular journey.... It never stops evolving just like some good CV.
My YouTuBe Page...
The patch you've created in your brain is more challenging to modify than the patch you have on your modular.
JakoGreyshire
Post by JakoGreyshire » Thu Dec 27, 2018 9:29 pm
Oh yeah, I would also get rid of the Tiptop one and get a Disting MK4. In the Disting thread someone asked about the TT One and the Disting comparison, and the result was that the Disting can do everything the One can and a TON of other things too... I
I've got a couple of Distings... They are very useful and are getting updates all the time... I should get a few more actually...
My YouTuBe Page...
gringostar
Post by gringostar » Fri Dec 28, 2018 12:08 am
Quantizer, wavefolder, mixer/polarizer/utilities, and modulation.
Quantizer to make the sequencer musical when you want it. Disting is good here.
Wavefolder as you have two great sounding analog oscillators and smashing them to bits is great. You have a lot to pick from.
Mixer/polarizer/utilities for more “fun” options. Again a lot of options, but I would look at the SSF tool-box and MIAx3.
Modulation as your options are a bit limited with just the DFAM. Lots of options but maths, rampage, stages, and PNW should be up there.
banalytic
Post by banalytic » Fri Dec 28, 2018 6:47 am
thanks a lot for your recommentations!
I still have maths in my other rack and won't use so much place in such a small case...
Now I have rearranged the dfam utility box:
JakoGreyshire
Post by JakoGreyshire » Sat Dec 29, 2018 4:45 am
budinis wrote:thanks a lot for your recommentations!
Nice.... So, it looks like you are doing some research... Good, Good...
Anyway, I was curious about how you are planning on using the Syncrodyne with the DFAM?
Ah! Well... In fact, what are your plans for all of this utility rack now that you've got it setup like this? Just curious... Looks like fun..
Happy Nerding MIA looks like a good option...
So, there is a dual sample and hold in the Disting... FYI..
Also the 2HP TRM is a passive Attenuation and as such it might be a waste of 2HP in the rack.... If it were my rack I would put the 2HP MIX in there instead and get some passive attenuation out of the rack...
Like these, but they have been out of stock for a while...
https://www.thonk.co.uk/shop/ryo-airtenuator/
The reason being is that having a mixer for CV and another mixer for audio is good for wiggling fun..
You've probably got other mixers in your rack though, eh?
Passive attenuation is good as well though... hmmmm....
:despair: :despair:
My YouTuBe Page...
Nutritional Zero
Post by Nutritional Zero » Sat Dec 29, 2018 4:06 pm
I recommend adding an LPG to any small modular setup destined to compliment the DFAM. The DFAM’s filter and VCA are competant and extremely good-sounding to my ears, but you might want something a little different at times.
Something like Optomix, LxD or Doepfer a-101-2 will give you some options for a natural and plucky sound.
I also echo the shouts for Pam’s and Maths. I’m unlikely to buy another Pam’s but I have four complex function generators so I’ll probably consecrate Maths to the DFAM rig.
I’m interested in seeing how different colours of noise sound through DFAM, replace the white noise/ext in normalization. I might try a Quantum Rainbow 2 to work with some darker tones.
Quantizer, bitcrusher, these are also things I have considered.[/url]
thisoldmike
Post by thisoldmike » Sun Dec 30, 2018 9:46 pm
I love my DFAM, I usually end up using it clocked by and in conjunction with a Digitakt to handle percussive duties. It's also a lot of fun when sequenced with a Beatstep Pro (main beat sequencing) and an SQ-1 (to sequence changes in VCA/VCF/VCO decays, velocity, FM amount, whatever). I usually have it running into a Disting mk4 running either a delay or a waveshaper. I should probably get another M32 to go with it, kinda regretting selling my first M32.
subLimb
Post by subLimb » Mon Jan 07, 2019 9:45 pm
thisoldmike wrote:I love my DFAM, I usually end up using it clocked by and in conjunction with a Digitakt to handle percussive duties. It's also a lot of fun when sequenced with a Beatstep Pro (main beat sequencing) and an SQ-1 (to sequence changes in VCA/VCF/VCO decays, velocity, FM amount, whatever). I usually have it running into a Disting mk4 running either a delay or a waveshaper. I should probably get another M32 to go with it, kinda regretting selling my first M32.
Curious how exactly did you get your DFAM clocked by the Digitakt? Or did you put the Digitakt through another device, and then into your DFAM?
thisoldmike
Post by thisoldmike » Mon Jan 07, 2019 9:50 pm
Ah, yeah. Forgot to mention that bit - the Digitakt MIDI out drives a CV.OCD for MIDI to CV. Works like a champ.
subLimb
Post by subLimb » Mon Jan 07, 2019 9:52 pm
thisoldmike wrote:Ah, yeah. Forgot to mention that bit - the Digitakt MIDI out drives a CV.OCD for MIDI to CV. Works like a champ.
Oooh, would you mind sharing your CV OCD settings? I have a bud thats trying to do this exact thing, only with the Octatrack -> CV.OCD -> DFAM and not having any luck.
thisoldmike
Post by thisoldmike » Mon Jan 07, 2019 10:15 pm
I just looked and can't find the config sysex file anywhere. A quick spin through the manual doesn't give me any idea if it's even possible to pull the current config off of it, and it's been months since I set it up, so... :despair:
banalytic
Post by banalytic » Tue Jan 08, 2019 4:28 pm
I also have octatrack --> cv.ocd --> modular:
Here is the configuration for midi-channels 13-16:
don't know how to upload the sysex here?! :doh:
but send me pm and a mail-adress and I send you the file.
subLimb
Post by subLimb » Thu Jan 10, 2019 7:22 pm
Thanks very much for the responses! I don't need the sysex file since you've uploaded the full settings image, so no problem there.
Thanks again!
Alphaman
Post by Alphaman » Mon Feb 04, 2019 12:01 pm
a few Ericas in a moog skiff for my Moogs. looks pretty awesome too. the DFAM is not on the photo. i need a 3 tier stand first^^
modul8tr
Post by modul8tr » Wed Feb 06, 2019 10:32 am
Hello all,
I’m trying to get my DFAM (which I’m VERY new to) setup with Reaktor Blocks where I plan to use the Kodiak Shift/Curve sequencers with it. I’m using the Expert Sleepers ES-8 and ES-3 to send CV/Gates etc.
Getting the sequencer to control DFAM via Expert Sleepers is straightforward. I have pitch patched to OSC 1-2 CV. Clock to ADV/CLOCK and velocity to velocity (and I’m open to any other tips here).
The biggest issue is just getting both oscillators tuned with Reaktor Blocks pitch cv tool . Somehow I got OSC 1 to tune once and it played in tune with some VST synth layers beautifully. Tuning OSC 2 so far is impossible. I hit the run button on pitch cv tool and NOTHING happens even though everything is set exactly as it was to tune OSC 1. Any insights/tips?
Xtheunknown
Post by Xtheunknown » Tue Feb 12, 2019 12:45 pm
Are the Moog DFAM envelopes one-shot (i.e. they must complete their full cycle before they can be retriggered), or are they retriggered before completion of their cycle whenever a new trigger is received (like a traditional ADSR)?
As always, your help is GREATLY appreciated!
HrBak
Post by HrBak » Wed Feb 13, 2019 5:09 pm
modul8tr wrote:Hello all,
I don't have a DFAM, but when I started to use ES-3 and NI Blocks and tried to tune my OSC I had the same problem you are describing. Turned out that I had to use a CV Block for every OSC and not just route the same Cv Block to more than one OSC.
rasabel
Som DFA
Post by rasabel » Wed Feb 27, 2019 6:24 am
Hi all DFAM's folks,first time posting ,love for all of you.
Recorded foggy and meandering musique concrète compositions with DFAM, shakers,and noises about "work"
Brain-pleasing outcomes in video for one of five tracks album below.
Peace.
inbrother
purpur
Post by purpur » Fri Mar 29, 2019 3:56 pm
Hey guys,
how do you squeeze maximum voices from your DFAM simultaneously without help form other modules (or maybe connecting only to m32)? I happen to patch TRIGGER out to VCA CV in order to get click on each steps filling the role of high hat or clave. It's post filter section, so the tone stays constant whatever I change in signal path. I think once I've got similar clicks with trigger out going pre-filter, so playing with resonance was giving them a bit more of character, but I can't quite remember how I patched it.
The Junglechrist
Post by The Junglechrist » Mon Apr 08, 2019 4:56 am
Hey there everyone ! We just uploaded this new video from our Patch From Scratch session, using the DFAM and the MF-103 Phaser to make some filthy beats :
Stazma The Junglechrist / Repeat Eater: http://stazmathejunglechrist.com/
Electric Voyage Studio [Mastering / Mixing] : http://electricvoyage-studio.com
My label Concrete Collage : https://concretecollage.bandcamp.com/
Wired Brain Video Channel : https://www.youtube.com/channel/UCh4pym ... vkKp6ofzVA
JakoGreyshire
Post by JakoGreyshire » Sat Apr 20, 2019 1:59 am
For those DFAM owners who also have a Mother-32, there is a patch book available for download at moog's website:
https://back.moogmusic.com/sites/defaul ... Book_0.pdf
My YouTuBe Page...
weird update
Post by weird update » Mon Apr 29, 2019 1:50 pm
Does anyone has excemples of people using the dfam to make ambient music or drones?
https://soundcloud.com/weirdupdate
Nibson
Post by Nibson » Fri May 03, 2019 7:22 am
I'd had my eye on a DFAM for about a year and have scoured through this thread a number of times. There's a ton of other modules I need (want) but I reached a personal goal so treated myself to a DFAM. It arrived yesterday and damn does it sound good.
I only played on it for an hour or so without patching into my case and it's a hell of a lot of fun. I make pretty heavy techno which it seems ideally suited for.
The sound is pretty distinctive so I wonder if the novelty will wear off of the sort of sound it makes..... But then I turn it on, smile and think there's not much chance of that :)
