Joranalogue COMPARE 2 - Dual Window Comparator
joranalogue
Post by joranalogue » Wed Oct 25, 2017 6:41 am
A comparator beyond compare
The window comparator is a very useful circuit building block that is common in general electronics, but rarely found in modular synths. While a regular comparator activates when the input signal voltage is higher than a threshold level, a window comparator checks if the voltage is between two levels (these form the 'window').
Compare 2 combines two such comparators and a logic section in 8 HP. The result is an advanced tool for extracting gates and pulses from analogue signals in Eurorack synths.
The detection windows are defined by the shift and size parameters, which can be varied using the knobs and CV inputs. Complementary gate outputs are available, with big three-colour LEDs showing each comparator's status.
All inputs are normalised from the left section to the right, but the two comparators can also be used completely independently. On the bottom, the outputs from both comparators are combined in various ways by the logic section, which also features LEDs.
You'll find a use for this truly multi-functional module in practically any patch, processing either CV or audio: complex rhythm generator, dual pulse width modulator, frequency multiplier/divider with PWM, digital ‘ring modulator’ with PWM, dynamic depth VCO synchronizer, voltage controlled swing, logic function array with adjustable thresholds... and many more applications waiting to be discovered!
https://soundcloud.com/joranalogue/compare-2-pwm-glitch
https://soundcloud.com/joranalogue/comp ... bot-groove
https://soundcloud.com/joranalogue/comp ... sing-tides
Lots more on SoundCloud: https://soundcloud.com/joranalogue/sets/compare-2 (thanks to my brilliant test users for sending these in!)
Available now!
More info: https://joranalogue.com/compare-2
ModularGrid: https://www.modulargrid.net/e/joranalog ... -compare-2
Pricing: €180 / £160 / $180 (MSRP)
8 HP, 30 mm deep
Joranalogue Audio Design
21st Century Analogue Synthesis—Made in Belgium
timoka
Post by timoka » Wed Oct 25, 2017 7:29 am
ah cool, looks exactly like the comparator i'm looking for!
what voltage are the gates out?
EDIT: nevermind, found it in the manual, it's +5V.
doskonale
Post by doskonale » Wed Oct 25, 2017 8:45 am
Looks really useful ! And i like the nice Serge-style leds.
Good job !
:love:
to be a sprinkler system in a thunderstorm
BillyB909
Post by BillyB909 » Wed Oct 25, 2017 11:07 am
This looks sweet. Is it genuinely sold out or is it simply the stock isn’t in yet?
joranalogue
Post by joranalogue » Wed Oct 25, 2017 11:21 am
BillyB909 wrote:This looks sweet. Is it genuinely sold out or is it simply the stock isn’t in yet?
Just announced the module, going into production really soon! It should be ready to go in 3-4 weeks. :banana:
Wish my webstore would allow me to hide the 'sold out' label for products that aren't released yet. ;)
Dcramer
Post by Dcramer » Wed Oct 25, 2017 10:33 pm
Dual window comparators with voltage controlled shift and size! :hail: brilliant!
Mikeyg3k
Post by Mikeyg3k » Wed Oct 25, 2017 10:50 pm
Will Control have this Joran?
I am really happy with the Switch 4! and would love to check this out!!!
Great designs. !!!
BaloErets
Post by BaloErets » Wed Oct 25, 2017 10:50 pm
This looks really impressive! On the top of my shopping list now! Love the design too. Great job! :nana:
TemplarK
Post by TemplarK » Thu Oct 26, 2017 12:19 am
This looks awesome! Actually just such a thoughtful design this is going to be popular i think once people catch on to it!
joranalogue
Post by joranalogue » Thu Oct 26, 2017 8:17 am
Cheers everyone for the response. I'm excited to see what other applications people will come up with once they're available - still scratching the surface myself after a year of development.
Mikeyg3k wrote:Will Control have this Joran?
Great designs. !!!
They should, but ultimately it's the dealers' choice which modules to stock. Although I think they wouldn't want to miss out on this one. ;)
joranalogue
Post by joranalogue » Wed Nov 01, 2017 7:17 am
New demo video: Multi-Pulse Width Modulation
Compare 2 can generate much more elaborate PWM tones than a basic pulse width modulator. Sending a single VCO sine wave to both window comparators results in growing, shrinking and shifting pulse waveforms on the outputs, modulated using the knobs and CV inputs. The video starts using the XOR output, then switches to the FF output, and finally back to XOR with LFO modulation of one comparator's size parameter.
vibralux
Post by vibralux » Wed Nov 01, 2017 4:46 pm
Wow - excellent idea. Plus - I am loving these huge leds - just like on Serge modules I used to own :nana:
MY YT CHANNEL WITH MODULES REVIEWS:
https://www.youtube.com/channel/UC3IgU2 ... hKH8ou7YTQ
MODULARS, ABLETON, MIXING. Stop reading manuals. Start making music.
http://www.colormysound.com/
joranalogue
Post by joranalogue » Wed Nov 08, 2017 6:11 am
Things get funky as we patch Compare 2 for dynamic depth sync of a single sine oscillator!
Using Compare 2, any VCO can be given soft-synchronization capability with dynamic depth. The master and slave VCO signals are patched to the two window comparator inputs. The XOR output is then used to frequency modulate the slave VCO via a VCA, which provides voltage control over the sync depth. Both VCOs are controlled by a sequencer, and the VCA is driven from an envelope generator. The only sound source is the slave sine VCO, modulated by Compare 2.
nrg242
Post by nrg242 » Wed Nov 08, 2017 10:59 am
A+ for the example videos. really shows some useful scenarios and demystifies things for someone like myself that starts to get nervous when looking at logic functions. looks really intriguing.
joranalogue
Post by joranalogue » Wed Nov 15, 2017 12:23 pm
nrg242 wrote:A+ for the example videos. really shows some useful scenarios and demystifies things for someone like myself that starts to get nervous when looking at logic functions. looks really intriguing.
Glad you like them, because here's a new one: turn your boring envelope generator into a chaotic modulation source using Compare 2!
An envelope generator's output is sent to both window comparator inputs, while the flip-flop (FF) output goes back to the EG's gate input. The envelope will now oscillate between two boundary levels, as determined by Compare 2's windows. In this patch, the envelope controls the FM depth between two VCOs. Additionally, the AND and XOR outputs each modulate one of them as well. Controlling any window parameter(s) with a LFO quickly results in a chaotic patch.
peripatitis
Post by peripatitis » Wed Nov 15, 2017 4:44 pm
so i was wondering, can this be used as a PLL?
joranalogue
Post by joranalogue » Thu Nov 16, 2017 7:37 am
peripatitis wrote:so i was wondering, can this be used as a PLL?
It should be able to work as a phase comparator. Add a slew and VCO, and you've got a PLL. This may be something to explore for the next video. ;)
peripatitis
Post by peripatitis » Sun Nov 19, 2017 4:26 pm
Nice, Thank you!
boramx
lepidopteran orgasm
Post by boramx » Sun Nov 19, 2017 4:54 pm
this is ace.
perfect design, and feature set. little tight, though!
good work!
joranalogue
Post by joranalogue » Wed Dec 06, 2017 4:46 pm
Compare 2 has arrived! You can get yours now from the Joranalogue webstore (EU only) or any of these these fine retailers: And don't forget to check out the awesome introduction video by ben_hex aka DivKid:
:nana:
TemplarK
Post by TemplarK » Thu Dec 07, 2017 2:16 am
Will a DiY version be available at some point?
bemushroomed
Post by bemushroomed » Thu Dec 07, 2017 3:46 am
Seems like a lot of fun, ordered! :party:
joranalogue
Post by joranalogue » Thu Dec 07, 2017 4:18 am
TemplarK wrote:Will a DiY version be available at some point?
No DIY version is planned for now; it's a very tight SMT design.
bemushroomed wrote:Seems like a lot of fun, ordered! :party:
Cheers! :party:
joranalogue
Post by joranalogue » Fri Dec 08, 2017 2:16 pm
Another brilliant application for Compare 2: stereo distortion! Check out the new demo recording below.
Using C2 as a stereo distortion unit. A TB-303's output signal is sent to window comparator 1, and the same signal put phase shifted to comparator 2. The outputs form a stereo pair. Each channel is sent through its own lowpass filter, being frequency modulated by the C2 XOR and FF outputs respectively. Using VCAs, snappy envelopes are applied to the FM signals.
Seems this one's really resisting being embedded, so just click here: https://soundcloud.com/joranalogue/comp ... /compare-2
bemushroomed
Post by bemushroomed » Sat Dec 09, 2017 9:12 pm
Why is the "ringmod" described as digital? Isn't this module analog?
