2hp - Arp
Mikeyg3k
2hp - Arp
Post by Mikeyg3k » Fri Nov 03, 2017 9:21 am
Didn't see anything about this module here yet - I picked one up over the weekend. Any thoughts? I am looking for some cool patch examples or tips.... seems like a lot of fun from what I've seen so far.
Paranormal Patroler
Post by Paranormal Patroler » Fri Nov 03, 2017 9:32 am
Hey Mikeyg3k, can I ask you a question since I have one on the way but I'm super curious until I get it? When you send CV to the Root input does the output change immediately even though there is no trigger to fire the arpeggiation? What I mean is, since the Arp acts acts as an offset value of the Root input, if I have the arpeggiation statically on the 5th note, will it always play a 5th of the CV input all the time?
I want the Output of the module to be able to follow my Root CV changes immediately (without requiring a gate to be fired) and then jump to arp notes whenever a gate is received, and I imagine that is the case, but none of the videos showcase the Root input usage, so I have to ask. I appreciate any input you can give on that matter. Let me know if I haven't made my question clear enough.
Mikeyg3k
Post by Mikeyg3k » Fri Nov 03, 2017 11:28 am
Hey! Great questions - I'm actually still on my quest trying to figure it all out. I racked it last night and studied the manual and then worked on another patch i had still going so I didn't really spend too much time with it. LOL.
Here is the link to the manual http://www.twohp.com/s/2hp_Arp.pdf
and the Page on 2hp's site. http://www.twohp.com/modules/arp
I will have a go at it this weekend and see if I can answer Your question.
Paranormal Patroler
Post by Paranormal Patroler » Fri Nov 03, 2017 11:42 am
Thank you for your answer. I've already read both the manual, the page, and watched all 2hp videos on instagram. They don't answer my question! Looking forward to getting an answer when you can, of course. Thanks!
sine language
Post by sine language » Sat Dec 23, 2017 4:57 am
Curious...any updates?
Paranormal Patroler
Post by Paranormal Patroler » Mon Dec 25, 2017 3:17 am
The way it works is as I expected. See my description above. Merry Xmas!
spukhaft
Post by spukhaft » Mon Feb 12, 2018 3:52 pm
Anyone have this? I'm trying to understand how it works as well.
If feed it a C note and a gate, what happens?
"It is not recommended to use these alternate modes if you plan to let Tony Rolando come play with your system."
cliffemu
Post by cliffemu » Mon Feb 12, 2018 4:13 pm
I have two of these and I think they’re great. The root controls the root note and the trig causes the offsets from the root to cycle according to the chord type and direction mode selected. The output is root note plus offset.
twohp
Post by twohp » Tue Feb 13, 2018 12:29 pm
Greg White covers the Arp in this video!
Paranormal Patroler
Post by Paranormal Patroler » Wed Feb 14, 2018 3:58 pm
SeattleDucati wrote:Anyone have this? I'm trying to understand how it works as well.
If I feed a C note to the root cv, and a gate signal to the trigger, what happens? If the mode is set to major, does it play the individual notes in a C major chord? Are additional gate signals required to trigger the notes?
Hey SeattleDucati. When you send a pulse to the Gate input the CV of the output will cycle through the notes in the currently selected chord.
If you send a C note at the root CV, and the current chord is Major triad, the CV output will be C E G (depending on the mode of course) and then C again.
spukhaft
Post by spukhaft » Thu Feb 15, 2018 9:53 pm
Just got this installed tonight. Will give it a run through tomorrow night. A bit scary installing the module. The pcb board hangs off the back a long way, and it's only held on with thin wires. Seems pretty delicate.
shoottofill
Post by shoottofill » Fri Feb 16, 2018 10:11 am
SeattleDucati wrote:Just got this installed tonight. Will give it a run through tomorrow night. A bit scary installing the module. The pcb board hangs off the back a long way, and it's only held on with thin wires. Seems pretty delicate.
thats the thing with the 2hp modules, to save space they seem a little fragile and the power cable is in an awkward place. But i have a few and once i squeezed them in I've never had a problem.
I do think the Arp is one of their better designs. I just let it run and don't have to wiggle the knobs much (but you may feel the need to)
Gyroscope
Post by Gyroscope » Fri Feb 16, 2018 12:53 pm
twohp wrote:[video][/video]
Man that guy is great at explaining the functionality of modules. I could listen to him all day (and probably will :hihi: ). Just serious presentations, no goofy faces while he's looking at the modules on the thumbnails in Youtube. Hats off!
loresdef
Post by loresdef » Fri Nov 09, 2018 7:52 am
Hi,
I'm having a good time with the Arp although something seems off to me and i wonder if some of you experience the same or that its just my module.
If i patch a cv into root in, root out gives me a 1 or two octave higher pitch when root pot. is fully ccw.
The manual says the position of the pot. is added to the cv in, but then it should be a copy of the cv in when the pot. is fully ccw right?
Thanks in advance!
LTodd
Post by LTodd » Fri Nov 09, 2018 3:56 pm
loresdef wrote:Hi,
Thanks in advance!
I imagine if you're sending a cv value higher than 0V into the cv root in, then you're getting a value of 0V + whatever cv value you're adding. Fully ccw is not going to convert incoming cv to 0v.
aphantomvaper
Post by aphantomvaper » Sat Nov 10, 2018 9:49 am
The Arp is a cool module. I like shoving a cv from the Rampage ab out on long cycle into the mode input (just above the LEDs). The slow mode progression against a drone is super fun!
Granular
Post by Granular » Sun Aug 11, 2019 4:11 am
Seems that the 2hp Arp is nowhere in Stock at Dealers in Europe.
Post by lisa » Sun Aug 11, 2019 5:58 am
Granular wrote:Seems that the 2hp Arp is nowhere in Stock at Dealers in Europe.
Here you go. :party:
https://www.signalsounds.com/2hp-arp-eu ... tor-module
https://soundria.com/2hp-arp.html
https://matttechmodular.co.uk/product/2hp-arp/
Icy and melodic braindance/IDM winter track. ❄️
Granular
Post by Granular » Sun Aug 11, 2019 6:10 am
:woah: Thanks Lisa :yay:
Do you have any experience with one of these Dealers?
IEC
Post by IEC » Sun Aug 11, 2019 6:14 am
had some good dealings with signal sounds in the past myself
Post by lisa » Sun Aug 11, 2019 7:37 am
Yep, Signal Sounds is a good vendor (purchased from them many times) and Mattech is a quite active members of this forum.
ericD13
Post by ericD13 » Sun Aug 11, 2019 7:59 am
Granular wrote: Do you have any experience with one of these Dealers?
Always had good experience with Signal Sounds.
"Unfortunately it took me forty years to conclude that nothing is possible outside DoReMi."
P. Schaeffer
Lots of 5U modules to sell in europe :
https://www.muffwiggler.com/forum/viewt ... p?t=219781
mosorensen
Post by mosorensen » Sun Aug 11, 2019 8:17 am
Also had good experiences with Signal Sounds. That said, my impression is that Soundria and MattechModular are also solid retailers. I have only heard good things about all three of them.
pieter
Post by pieter » Sun Aug 11, 2019 11:07 am
MattTech Modular is super reliable; he's my first stop for modules, and only if he doesn't have it do I look elsewhere (typically Rubadub is my next port of call).
mmpingo
Post by mmpingo » Fri Aug 16, 2019 2:55 am
Lisa gave us a few links but in fact there's a problem with 2hp modules availabiity. I can't buy the Arp in my country (and in really good prices!) and the only thing the local shops can offer is a waiting list. So I wait in a line for over three months...
As for the Signal sounds...
