Oakley VCO switched octave course range ?
banjostring1815
Post by banjostring1815 » Sat Nov 04, 2017 7:26 am
Has the Oakley VCO ever had a modification whereby the course range control pot has been substituted with a resistor chain rotary switch instead ?
(Such as on the Moog 901a) where each turn raises or lowers an octave.
If anyone has done it would they explain how it's done (if it is possible) ?
Pav
Post by Pav » Sat Nov 04, 2017 1:52 pm
https://www.muffwiggler.com/forum/viewtopic.php?t=78996
If I've cut and pasted right..here is q&a on same topic from 2013.
rgds Pav
terjewinther
Re: Oakley VCO switched octave course range ?
Post by terjewinther » Sat Nov 04, 2017 4:45 pm
banjostring1815 wrote:If anyone has done it would they explain how it's done (if it is possible) ?
I have modified one of my Oakley VCOs with an octave switch. I just feeded the + and - side to a row of trimmers, one for each octave.
banjostring1815
Post by banjostring1815 » Sat Nov 04, 2017 8:34 pm
Thank you for these replies.
This will make life easier as I do frequent octave switching. The trimmer is a good solution.
I deduced that there are about 5-6 octaves controlled by the Course Tune pot.
But in the low frequency end its difficult to hear octaves.
I guess a rotary switch ...resistors and trial and much error.
