Prophet 5 issue - DIY'ers please suggest?
Author Prophet 5 issue - DIY'ers please suggest?
Ranxerox
My rev 2 Prophet 5 has developed a fault whereby osc B is way way quieter than oscillator A or the noise source in the mixer section. The knob for osc B only affects loudness in the first 10% or so of the throw (and seems a bit spotty at that). Otherwise the oscillator seems to behave normally...
Could it be the pot itself? Or a chip in the mixer section? Any suggestions greatly appreciated hmmm.....
Dr. Sketch-n-Etch
Without knowing anything about the circuit, my first guess would be a dodgy pot. Is it easily replaced? If you can gain access to the pot terminals with the synth running, then you can determine whether the pot is receiving a full-strength signal or not.
Ranxerox
Thanks, your advice made me finally look into the service manual! The pot is a 100k linear that's buried behind one of the other boards, but shouldn't be too hard to get to in the service position. If that's not the problem, then the mixer section uses three 4051 op-amps, hopefully won't be too hard to trace if one of them is faulty...
Graham Hinton
If the fault is the same on all five voices then it's not the mixer section. What about patches from memory? If they are higher volume then it's probably the pot or the multiplexer that routes it to the ADC, if they have OscB low too then the fault will be in the CV path from the DAC to the OscB level control.
Ranxerox
A good point, thanks Graham. Osc B seems to be quiet for all voices, and irrespective of whether from a recalled patch or in edit mode. So it would be logical to assume the problem is on the DAC side of things, as you say...
oldgearguy
without knowing your level of experience, I have to caution that opening up and diagnosing and servicing a rev 2 Prophet 5 is not fun nor easy. Standing it up on end so the machine can be opened and have the boards connected and yet not shorting out while you reach inside with a scope or DMM can be a challenge.
Of course, if you've spent a lot of time teching your own gear and have dealt with the various manufacturers methods of assembly, then it shouldn't be too much of a problem.
Ranxerox
Thanks, yeah I've opened her up a couple of times before and serviced a few of my bits a pieces over the years, but I'm hardly an expert.
I'm hoping it's something cheap and relatively simple to diagnose, like a faulty op-amp. It could be either the relevant 4051 de-mux chip (U346) or the TL082 down-stream of pin 15 (U349), which controls the osc B mix VCA.
I don't think it's the latching s/h chip up-stream of the de-mux (U356), or there would be multiple issues - that 4051 controls quite a few parameters as well as osc level.
If the above turns out not to be the source of the problem then I'll probably have to admit defeat - and be in for a costly service cry
sneak-thief
This is the order of likelihood of failed components that I would replace:
OSC Mix pot - you can measure the output pin to see if it's putting out the full range of 0-5V as you rotate it. Also, check the pot for dry joints.
From page 41 of the PDF manual, aka "PCB2 POT MUX":
U202 - CD4051 - these blow all the time
And from page 46 of the PDF manual, aka "3-13 PCB 3 CV DMUX/LATCHES":
U356 - CD4051 - these blow all the time
U361 - TL082
Q302 - 2N4250
R322 - 33k - not very likely, but still possible!
The Rev. 2 is the only synth repair I walked away from - and I've repaired most of the big polys, CS70m, Ob-Xa, Synthex, JP8, JP6, JP4, P5 Rev. 3, etc. In this case, a decoupling cap had too much solder on it and it eventually moved and shorted out the whole thing. I eventually got tired of testing and replacing all the broken chips while walking a tightrope to not blow up any/all of the unobtanium SSM chips and gave it back to the owner.
It also looks like crap inside, with flying bodge-wires right out of the factory.
Ranxerox
U361 - TL082
Q302 - 2N4250
Thanks, it's reassuring to know the 4051 is an obvious target - however I think you're citing the parts references from the Rev 3 technical manual? In any case, this is a helpful list of likely suspects. I think from process of elimination we've determined the problem is post-DAC, as it affects all patches whether in edit mode or not, eliminating the pot - but I'll check it anyway, just in case.
It sure does look pretty funky inside, and with so many ways to go into critical failure mode, I've heard it's a servicing nightmare... I think Oberheim's contemporaneous approach with the OB-X (separate cards for each voice, rear-panel case hinge - like opening the bonnet on a Ford F150!) was much nicer.
sneak-thief
Oh dang, I opened the wrong PDF.
Lemme try that again...
From page 61 of the PDF manual, aka "CONTROL PANEL POTS":
And from page 78 of the PDF manual, aka "TUN MUX, S/H, AUD OUT":
U346 - CD4051 - these blow all the time
U349 - TL082
C322 - 0.01 poly
