General CV firmware update announcement thread
Author General CV firmware update announcement thread
This thread will serve as a means for announcing General CV firmware updates. Please watch this topic for replies if you would like notification of such updates.
Please keep chat to a minimum on this thread - discussion, support requests etc. can be posted as new topics.
v1.1 is released:
* Added a setting for time until display blank.
* Added 'panic' menu items for all notes/sound off.
* Added control over the output gain (offering up to 6dB more volume compared to v1.0).
http://expert-sleepers.co.uk/generalcvfirmwareupdates.html
v1.2 is released:
* Added 'Additive' mode.
* Added the ability to redefine the mapping of CV inputs to parameters.
* Added control over the effect of the 'Mod Wheel' parameter.
* Added a 'Mod Wheel' parameter to 'Chord' and 'Arpeggiator' modes.
* Added envelope and filter scale parameters to 'CV To MIDI' and 'VCO' modes.
* Added options to disable reverb, chorus and EQ and thus increase polyphony.
* Added a setting for an initial preset to load at startup.
* Added a 'factory reset' menu item.
* In 'Free Playback' mode, retriggering a MIDI file now sends an 'all notes off'.
v1.3 is released:
* Added 'Granular' mode.
* Added 'Shepard/Risset' mode.
* Added the ability to control the per-channel programs in 'Clocked Playback' and 'Free Playback' modes.
* Added the 'Uni (inv)' mapping mode.
* Added the 'parameter chase' display mode.
* Added the display of a parameter's last saved value while editing the parameter.
* Added the ability to assign a CV input to control the current preset.
* Made velocity a mappable parameter (rather than being hard-wired) for 'CV To MIDI', 'VCO', 'Drums', 'Chord', and 'Arpeggiator' modes.
v1.4 is released:
* Added 'Programmable' mode.
* Added a setting to enable sending all generated MIDI out to the MIDI breakout.
* Added per-preset 'Fine Tune' control.
* Added per-preset external program change.
* Fixed a problem where the display could become corrupted.
v1.4.1 is released:
* Fixed problems with input analogue to digital conversions which could lead to a number of issues, most visibly mapped parameters being randomly reset to zero.
* Fixed incorrect scaling when using inputs 1-3 for pitch in Programmable mode.
* Fixed hanging notes when switching between VCO and CV/MIDI modes.
* Added support for the new form of the Select Bus save state message implemented by the Make Noise René 2.
v1.4.2 is released:
* Fixed a crash when attempting to use the save to/load from SD card menu items.
v1.4.3 is released:
* Fixed a problem where the module would continually load a preset.
