36dB VCF LP/HP with gain loss compensation on high Q
Author 36dB VCF LP/HP with gain loss compensation on high Q
Haralds:Werk
I just wanted to know how a 36dB VCF sounds like. So i build one. This one is basically derived from my 24dB VCF LP/HP which i build for my Next Generation Formant Elektor project. I just added two more filter stages and the compensation circuitry from my Moog Ladder filter to compensate for the volume loss when Q is turned up. I have brought out all 6 filter stage outputs. Depending on your wiring you can use a switch to select between the outputs or/and bring all outputs out in parallel. The LP/HP switching is done with electronic switches on the PCB to avoid the problems (hum, noise...) of the wiring with a mechanical switch.
Specs and features
36dB voltage controlled low pass and high pass filter
Switchable output 6dB, 12dB, 18dB, 24dB, 30dB, 36dB
Volume loss compensation with high Q
10Vpp signal level
Voltage controllable Q
Voltage controlled lin and log timbre modulation
Positive and negative ENV control with sign changer
Runs on +/-15V and +/-12V (with minor resistor changes)
Power consumption below mA each rail
Volume indicator (optional)
The documentation for download can be found in my website.
Straight forward design. Six state variable filter cells are connected together in series, The output of each filter cell is brought out. There are a lot descriptions of those state variable filters out there. I feel no need to add another one. The resonance (Q) is voltage controlled with means of the OTA IC16OTA2 in the upper right corner (page 1). To compensate the volume loss when the resonance (Q) is turned up a second OTA (IC16OTA1) is used. This two OTA shares the same Iabc source. The amplification of this second OTA is increased when Q is going high and add volume to the output signal (See page 2 of the schematic).
vtl5c3
Looks interesting. Do you have any sound demos?
Haralds:Werk
No, sorry. I will post some sound demos here asap.
pugix
Interesting panel design. Do you make all your own modules and panels? It looks sort of like MU, but with bananas!
Haralds:Werk
Thanks. Yes all modules and panels are my design. The schematics and PCB are made with Eagle and manufactured by Elecrow. The panels are done with FPD and manufactured by Schaeffer. More examples on my website.
pugix
I should have looked at the links on your first post! Your work is impressive. Very clean designs and assembly. I like the use of headers on the PC boards for all panel wire connections.
emmaker
With all those OTAs how noisy is it?
Haralds:Werk
I have optimized the SNR using the linearization diodes and driving the OTA with high Iabc. I don't have the equipment to measure the SNR so the following is a bit subjective. When i turn my PA all the way up and open the filter completely with no signal attached I can here some noise. Closing the filter with the cut off potentiometer lowers the noise. So this filter add to the overall noise. But lowering the amplifikation of the PA to a level my ears can stand without doing harm to them and using the filter with signal attached the noise is not audible for me. It must be there but the signal to noise ratio is quite good. At least to my ears.
Haralds:Werk
Yes those connectors give you a lot of freedom for the wiring and the panel design. However I moved on to a "flat" design in some cases. No more wiring needed and the depth of the module is lower. But you need two PCB in most cases. Changing the panel design now needs changing at least one PCB as well.
jobbyjaws
I would love to hear some sound examples/a quick demo of the features. Can't seem to find any on your website
woodster
Interested in hearing this, 36db High Pass sounds like fun to me.
