FH-1 Midi Start & Stop... what about old "continue&
Author FH-1 Midi Start & Stop... what about old "continue&
lessavyfav
I've got my clock set to stop on midi stop/start from the controller but it ignores "continue" messages. My MPC sends start when you play from the beginning but the rest of the time sends continue (decimal 251, hex 0xFB)
Is there any way to map to treat continue and start the same for starting the stopped LFO?
That's a bit of an oversight, there, sorry.
Start and continue wouldn't be treated the same - continue should not reset the LFO phase, as start does.
I'll put that on the to-do list.
Could you see if this does what you expect?
willu47
I've tested this and it works fine. I'm using a Teenage Engineering OP-1 with the FH-1, the OP-1 only sends continue and stop messages. I've now successfully clocked LFOs to the midi clock which start and stop when I hit play on the OP-1. Awesome!
