ES-8 Standalone "crackling Sound".
Author ES-8 Standalone "crackling Sound".
Chrism
Hello!
I bought an ES-8 and would like use it in standalone Mode.
I connect the ES-8 (Firmware 1.2) over Adat (Input & Output) with my Steinberg UR 824 Audio Interface.
The UR 824 Adat Clock is set to internal (master).
I become Audio but it´s crackled and sometimes loose Audio.
Whats wrong? hmmm.....
Many Thanks for Tips or solutions!
Best,
Chris!
Where are you hearing crackles exactly? On audio coming in through the ES-8? On audio going out of the Steinberg (e.g. to your speakers)? Somewhere else?
Chrism
Hello OS,
i have make some Tests.
1. Simply connect the In/Out from Steinberg (Master) in the ES-8 (Slave)
Send Audio from Ableton through the ES-8 and back.
This result in Crackles and random Signal lost.
2. Simply connect the In/Out from Steinberg (Master) in the ES-8 (Slave)
Send a Audio Signal from a VCO through the ES-8 to Ableton.
3. Connect only the "Out" from ES-8 (Master) to Steinberg (Slave)
Audio is fine.
3. Connect only the "Out" from Steinberg (Master) to ES-8 (Slave)
Send a Audio Signal from Ableton through the ES-8 to my Steinberg
Analog In. Audio is fine
I think there is a Clock Conflict between the Devices.
Whenever both Adat Lightpipes (Input & Output) are connected the same Time, there are these Dropouts.
But it´s a simple Adat In/Out connection as Master & Slave.
Send the ES-8 the received Clock back to the Steinberg?
There are no concrete Settings with the ES-8.
The Manual say the ES-8 goes automaticly in the Slave Mode by a incoming Clock Signal.
Correct, which you see in your 4th test.
Can I see a screenshot of your Steinberg settings?
Chrism
Here the Settings:
The first & second Test try with different Buffers,- Sample Rates
(44,1khz/ 48khz) and 3 different Lightpipe Cables. Dead Banana
Looks OK. Do you have the latest Steinberg driver?
Chrism
Yes, the latest Driver are installed.
I will try an ES-3 & ES- 6 Combo... .
it was ordered now.
I will write you the results.
Chrism
Hello OS,
the first Test with the ES-3 / ES-6 Combo works fine!
No Glitches or other Issues. It's peanut butter jelly time!
Chrism
Finaly, "all" works perfect with my new ES-3/ ES-6... .
Good news.
