Swirls/Lamb (8hp Tides/Sheep)
electric mist
Post by electric mist » Sat Feb 24, 2018 8:01 am
Hey. Did someone build it? I would be curious to have opinions.
Altitude909
Post by Altitude909 » Sat Feb 24, 2018 8:06 am
electric mist wrote:Hey. Did someone build it? I would be curious to have opinions.
Yeah, works fine. There were some clearance issues and I added PSI power on mine but overall, it was fine. Good layout
electric mist
Post by electric mist » Sat Feb 24, 2018 8:12 am
Altitude909 wrote:Yeah, works fine. There were some clearance issues and I added PSI power on mine but overall, it was fine. Good layout
Cool. On which area do you had some clearance issues ?
Altitude909
Post by Altitude909 » Sat Feb 24, 2018 8:16 am
all over. Download the PCBway DRC (which is "standard" design specs for most fabs) and run it, it will find them all. Also, your via's were kind of large diameter wise. I usually go 13 mils on those so they always get tented and they can print over them
electric mist
Post by electric mist » Sat Feb 24, 2018 8:32 am
ok. I used the DRC of the original module. No probs with my boards from EasyEda. I had check with them before I ordered some. Next time i’ll check other pcb house specs. Yeah the via’s are a bit large I notice this. Smaller ones would have made the routing process easier...
Thanks for the feedback !
Altitude909
Post by Altitude909 » Sat Feb 24, 2018 9:31 am
It's probably splitting hairs about the clearances, I doubt it will trip anyone up
What I changed:
Thonkiconn jacks, the holes were painfully small on those.
added PSIpower
Changed crystal to smaller size
adjusted vias to 13mil
trip
Post by trip » Sun Feb 25, 2018 8:32 am
Altitude909 would you be willing to share your updated eagle files? Been meaning to make those changes myself but haven't got round to it.
Altitude909
Post by Altitude909 » Sun Feb 25, 2018 1:55 pm
trip wrote:Altitude909 would you be willing to share your updated eagle files? Been meaning to make those changes myself but haven't got round to it.
Yeah, I just need to update the BOM and I'll publish everything
tetsutestu
Build issue: ground problem?
Post by tetsutestu » Tue Mar 13, 2018 6:11 am
EDIT: Managed to fix it! Replaced the OP-AMPs, one of which I had placed incorrectly; and replaced a transistor as well. Yay!
How awesome to have a working Tides in 8HP.
Thanks Electric Mist!!!
Hi! I guess this is place to go for advice on Swirls.
I managed to build my Pusherman version "successfully" but I'm having some issues with low volume and a loud humming sound from the UNI and HIGH output.
The weird thing is is that I can hear the module working (ie. I can hear quantized sequences coming from the UNI out, but barely audible over the hum. (the BI out works perfectly BTW)
Is this a ground problem?
I did a finger test and I found that if I touch adjacent jacks with my finger the volume increases. So I decided to connect the bottommost legs of the BI and UNI jacks to each other with a wire. This brought the volume up, but the humming noise still persists.
Aside from this, the functionality of the module seems normal. I'm flummoxed!
Can anybody suggest a possible solution here? Where should I be looking?
FYI, here is a short clip of the UNI out humming noise:
https://soundcloud.com/joshua-stefane/s ... 1953_1.jpg[/img]
Altitude909
Post by Altitude909 » Tue Mar 13, 2018 6:33 am
https://github.com/altitude909/Eurorack ... SwirlsV1.2
trip
Post by trip » Tue Mar 13, 2018 9:09 am
wedaman
Post by wedaman » Wed Apr 25, 2018 3:16 am
Hello
I tried installing Sheep Firmware after making Swirls.
I pressed the A button with power on. The problem is that the three LEDs do not blink yellow. Three LEDs are flashing red. Of course Sheep Firmware can not be installed.
Do I have to install Firmware again from jtag?
electric mist
Post by electric mist » Sat Apr 28, 2018 12:57 pm
wedaman wrote: I tried installing Sheep Firmware after making Swirls.
Does the module operate properly with the Tides firmware ?
wedaman
Post by wedaman » Sun Apr 29, 2018 8:46 pm
Thank you for your reply.
Yes, It works with Tides firmware.
Altitude909
Post by Altitude909 » Mon Apr 30, 2018 5:32 am
wedaman wrote:Thank you for your reply.
How did u install tides?
wedaman
Post by wedaman » Mon Apr 30, 2018 6:48 pm
Thanks Altitude909.
I used win10, vagrant and ST-Link V2.
wedaman
Post by wedaman » Mon Apr 30, 2018 6:51 pm
Thank you everyone.
My problem was solved.
I thought there was a problem around the LEDs circuit. I checked the schematics.
Three LEDs were connected to STM32F103CBT6.
It was difficult to solder the STM32F103CBT6. I soldered it again.
When I press the A button with power on, the three LEDs blink yellow.
After that I could install Sheep firmware. :hyper:
Swirls / Lamb is a wonderful module !
electric mist
Post by electric mist » Wed May 02, 2018 5:29 pm
wedaman wrote:Thank you everyone.
Glad you’ve fixed it.
Enjoy !
zlance
Post by zlance » Sat Jul 07, 2018 8:22 pm
wedaman Did you build the entire board before you started flashing? I only loaded SMT components on the board and power connectors and I can't seem to get the STM32 visible by my stlink.
PS I got the 1.1 version pcbs
ilovesoldering
diodes directions
Post by ilovesoldering » Thu Aug 16, 2018 3:20 am
Hi guys
Does any body know the 2 diodes 1n5189W directions for this module? Couldn't work out from the pics...
pathein
Post by pathein » Thu Aug 16, 2018 6:06 am
from the perspective of looking at the board with diode side, red line to coincide with the line on the diode.
edited:board picture is from the 1.1 version
ilovesoldering
Post by ilovesoldering » Thu Aug 16, 2018 9:48 am
pathein
thank you so much!
electric mist
Re: diodes directions
Post by electric mist » Thu Aug 16, 2018 3:12 pm
ilovesoldering wrote:Hi guys
Hey, you should use the Eagle files when you built. It’s useful to locate parts (with the “show” command) and look at the orientation. There’s also an ULP somewhere on the inter webs that allow to show parts per value. A game changer !
electric mist
Post by electric mist » Thu Aug 16, 2018 3:18 pm
ilovesoldering
Post by ilovesoldering » Fri Aug 17, 2018 3:45 am
Wow! Omg! Thank you! we were just talking about this kind of app when we were in the modular workshop a month a go!
