*VIDEO* Music Thing Modular Spring Reverb mkii
Author *VIDEO* Music Thing Modular Spring Reverb mkii
ben_hex
AVAILABLE HERE - https://www.thonk.co.uk/shop/mtm-spring-reverb-mkii-kit/
Here's the mkii / mk2 or version 2 (call it what you want!) Music Thing Modular - Spring Reverb. It's a fantastic 6HP Spring Reverb module that has RCA connectors for a Spring tank around the back of the module or has them on a breakout expander which also let's you blend between the tank signal and the accutronics digital brick (which you should also buy, with the expander, as blending a tank with that is great!) The module also has a tilt EQ function that adjusts the signal into the reverb to adjust the tone and response (heavy bass transients can make those springs slap around) as well as a fully WET output and feedback input for creative patching, a XFADE input.
https://youtu.be/dQl8YyCtgHE
calvinsomething
Is Thonk where people in Canada buy Music Thing modules from? Is there a better way?
