Loop Switch on V1 CocoDeer not working, advice welcomed!
MUFF WIGGLER Forum Index -> Ciat-Lonbarde
Author Loop Switch on V1 CocoDeer not working, advice welcomed!
Ras Thavas
Any suggestions for a non-lighting and non-functioning loop hold switch on a V1 Cocodeer? I've had it about 1 1/2 months and suddenly the right loop switch won't light and the loop won't go into hold. The delay works fine, but the feedback can't be locked. I've gently popped the switch out from the front panel, all soldering seems intact on the switch itself. Soldering problems on the main board connections perhaps or a faulty switch? Somewhat devastated as I really have been enjoying this beautiful machine.
GhostlyMostly
waah
Sorry to learn about this. I just emailed you back. Any local CL cats close to you that could take a look at it?
The layout schematic is so vastly different from V1 to V2
I hope this is resolved quickly
Best regards
