ES-5 Controller plugin
Author ES-5 Controller plugin
edoway
Hello!
I am trying to use the following set:
ES-3 MkII
ES-5
EXS-8CV
I want to use the ES-5 Controller plugin and in the manual I read
All the controls of the ES-5 Controller work in exactly the same way as the similarly-named controls in the ES-4 Controller, except that where the ES-4 has 5 channels, the ES-5 has 6. So there are 6 Output knobs, 6 pairs of knobs in the Gates section, and the controls which specify a gate output go up to “6/8” instead of “5/8”.
But my ES-5 Controller has only 5 outputs to choose from in the "Outputs to gates" section. It goes 1/1 to 5/8, not 6/8.
Is this correct so or there is a problem?
I am using version 2.6.0 AU.
Thank you!
Well - you've found a bug, that's been in there for 5 years or more without anyone noticing! I'll make a note.
