µTune Midi expansion + Intellijel 7u case
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
tubbutec
Post by tubbutec » Fri Dec 22, 2017 2:43 am
I have a µTune and recently also acquired an Intellijel 7u case. I
was wondering if it would be at all possible to connect the µTune to
the Midi ports that are built into the case via the expansion port. Do
you have any idea if this is possible?
This should be possible, but needs a bit of soldering. Can you provide closeup pictures of the Intellijel midi board in the case? Maybe even remove it to show the underside of the board?
hdh
Intellijel 7U Midi Module Photos
Post by hdh » Sat Dec 23, 2017 11:32 am
I removed the board to get a few photos. I have to write 2 posts to upload the pictures, tho. So, I'll keep them to this thread. :)
hdh
:hyper:
hdh
Photos: this time I mean it.
Post by hdh » Sat Dec 23, 2017 11:38 am
Here are the photos. Apologies, the lighting is not that great.
Front view. MIDI plugs in this view are are (L to R): through, out, in.
Let me know if you need any more details. I'm not an expert at soldering, but I can get by.
Thank you!
tubbutec
Post by tubbutec » Sat Dec 23, 2017 12:04 pm
I believe this is the correct way to solder. Id it does not work, switch connection 1 with 3 and 4 with 5.
A better way would be to use a connector for the pin header. We'd need to figure out the correct connections + Given your solder experience, just soldering 5 wires is probably the easier way.
Return to “Tubbutec”
