How would you make analog tympani? Any examples?
Author How would you make analog tympani? Any examples?
Infrablue
Really want to make some analog Tympani.
I searched and found this amazing, but sadly rare instrument.
How would I do this?
I do have an Mbrane11 but not quite getting this kinda thing.
This vid blows me away.
Synare Tympani:
Back in the 80's when I had a Korg MS-20 I could get decent tympani. Not as good as that video. I remember using the Pink noise as part of the sound and modulation, but I can't recall the rest. If I had an MS-20 in front of me I could dial it in. Tympani, explosions and birds were so good on the MS-20. I also liked the patch books Koto sound.
I recently bought a Boss SPD-One, so my tympani is covered. Mr. Green
commodorejohn
Yeah, if I had to pick a synth the MS-20 would be a good choice. Generally speaking, the body of the sound can be done with a ring-modulation metallic timbre dialed in appropriately (octave + 4th interval seems to be good.) On the MS-20, oscillator 2 can provide that while oscillator 1 can be set to a triangle wave down on the lower part of the ring-mod pair to boost the low end a bit. Noise should be added in appropriately, while the lowpass filter (with resonance off) shapes the overall timbral envelope. The high-pass filter can have the resonance cranked up to just this side of self-oscillation and set to a static frequency to provide "body resonance." Beyond that, it's largely a matter of setting up the envelopes correctly.
dashwood
I would say you could get very close to that on a Vermona DRM1.
thevegasnerve
I had luck with a Vermont Kick Lancet..
This might be of interest:
https://github.com/micjamking/synth-secrets/blob/master/part-32.md
revtor
That’s Synare sounds very realistic. If I was looking for a Timpani sound that was so realistic I would probably just use a sample.
Years ago Elhardt on the MOTM maillist put together a bunch of synthesis patches and notes for doing very realistic percussion. He was (is?) a champ of that. Not sure if He’s here on muffs...
Steve
This may be interesting, lead to extended investigation or be totally useless? hmmm..... hihi I first saw information like this in The Acoustical Foundations Of Music by John Backus, which was the required text book for a physics of acoustics class I took in college.
http://ummalqura-phy.com/HYPER1/cirmem.html
Infrablue
Thank you, guys.
Samples tympani sure can be great for sure.
I'm just working on a long term classical electronic album and trying to pretty much keep it to analog.
Even though turns out Tomita used a real sitar on Firebird and actually sang the lead female (gorgeous) melody for Venus in The Planets, I can't quite bring myself to use samples in this project. Just boundaries I'm setting for myself to see what I can come up with using mainly analog. Not usually for emulation but for similarity of expression.
lol for years I just wondered in amazement how Tomita synthesized that female voice.
Infrablue
Very cool and a little over my head as far as implementation for synthesis but that's not a bad thing to come across for me. Thank you! smile
Don't feel bad, it's over my head too! hihi oops I used to play acoustic timpani up through the college level so this was very interesting to me.
At the very least, if you ponder all the ways that the head can vibrate, you might try using several synth voices mixed together with possibly envelope followers tracking some voices that affect are patched to affect other voices? hmmm.....
If you've ever been a fan of Larry Fast and his great Synergy albums you might recall the pretty darn good timpani he synthesized (especially for 1978) on the Chords album? Sounds like he used a fair amount of noise (maybe a tad too much?) and some part of the sound has a pitch drop (or maybe a filter roll off on the reverberated sound?), plus likely multiple reverb units/passes? Maybe you can research how he did this or maybe even write to him and ask? If you talk to him tell him he is one of my greatest musical heros! Hug
