DIY - Elektor Vocoder - New kits available now !
Fitchie
Post by Fitchie » Fri Nov 09, 2018 1:53 pm
elmegil wrote:I assume they are going through the list top to bottom, and that they are going to take a few days to get it all out?
All of which is fine, but I'm still worried I may have deleted something important.
Hi Elmegil,
Your reasoning is entirely correct and you didn't miss anything, but BPost messed up things due to a one week-long strike. Some days their administration department is not available, other days the distribution is not working, and now they have a huge backlog. 90% of all staff are involved, so you can imagine what kind of disorder it is. But according to the latest news, they have reached an agreement and from Monday all services should be restarted. My apologies, this is completely out of my control.
Where are we now:
- All parcels for the United States, Canada and other countries outside the European Economic Community are prepared, labeled, provided with customs documents and delivered in the local sorting center.
- The packages have not been scanned for further processing, I hoped this would be done today, but unfortunately this did not happen. Presumably this will happen on Monday or Tuesday, this according to the incurred backlog.
- As soon as the packages are processed I'll receive the tracking information for each individual parcel. Once as I have this information, I will forward it to you.
So I would like to ask you on behalf of BPost to be patient for a moment.
Once again my apologies...
:eek:
elmegil
Post by elmegil » Fri Nov 09, 2018 2:41 pm
Strike's not your fault :)
Thank you for the very clear description, I will go back over to my corner and be patient :-D
elmegil
Post by elmegil » Fri Nov 09, 2018 4:09 pm
New questions, regarding the BOM. If those ought to go some other thread, let me know.
1) is there a reason all the resistors in the BOM are 1/2W versions? These are 10mm long per the datasheet on the farnell (newark/element14) website, is that really what you used? Or should those all be MF25's instead of MF50's?
2) Any suggestions for a source for the WAGO Solder pins? Newark doesn't even say they have them in stock right now, and I haven't found them elsewhere.
3) with regard to the DPDT switches on the FP and Noise section, Mouser has Mountain 1MD1T1B1M1QE which appear to be equivalent (down to the part numbers) except these are B1 and what's in the BOM is B5 -- the difference is that the B1 is a couple mm higher in the bushing and has a keyway, B5 is shorter and is flat. The one doubt I have is -- does the panel expect these to be flat-sided switches (in which case the bushing of the B1 won't fit). Mouser doesn't have the B5, unfortunately.
Probably more questions as the day winds on.
Fitchie
Post by Fitchie » Fri Nov 09, 2018 4:21 pm
elmegil wrote:1) is there a reason all the resistors in the BOM are 1/2W versions?
1/8 W or 1/4 W resistors are perfectly suitable.
I consciously did use 1/2 W resistors to get the old-fashioned look of the original device.
elmegil wrote:2) Any suggestions for a source for the WAGO Solder pins?
These pins are ordinary 1 mm solder pins:
  • - Farnell reference: 2643506
    - TME reference: 1364E.61
    - Newark reference: 07WX0901
    - Reichelt reference: RTM 1-100
elmegil wrote:3) The one doubt I have is -- does the panel expect these to be flat-sided switches (in which case the bushing of the B1 won't fit)
No, the panel is 2,5 mm thick, so you have to add washers at the inside at your own discretion.
elmegil
Post by elmegil » Fri Nov 09, 2018 6:11 pm
But no mouser, and searching for 1mm solder pin gets me so much more than I could possibly sort through :cry:
Not your problem, at all. I'm just at a loss to figure out how to find them, there's no way all those places have them and not Mouser.
PS: I don't buy from those places generally because their shipping is ridiculous -- as would be expected Europe to US
elmegil
Post by elmegil » Fri Nov 09, 2018 7:32 pm
I think I finally found something compatible
https://www.mouser.com/ProductDetail/Mi ... Xwr3eVKNuB
or
https://www.mouser.com/ProductDetail/Mi ... pEhg%3d%3d
Though the latter are pretty spendy
The problem is the only ones Mouser carries that aren't gold plated are .5mm or so rather than 1mm diameter.
Fitchie
Post by Fitchie » Sat Nov 10, 2018 6:49 am
Great news !
The strike at BPost is definitely over.
Got an update with the confirmation that all packages for the United States, Canada and other countries outside the European Economic Community are scanned and accepted by the distribution network.
:yay:
If you want to receive your private tracking number, please send me a private messages and I'll respond as soon as possible.
elmegil
Post by elmegil » Sat Nov 10, 2018 9:33 am
Thanks!! :yay:
jersupereq
Post by jersupereq » Mon Nov 12, 2018 12:51 pm
jaidee wrote:
seanpark wrote:
Everyone who contacted me for 3080s: packages went out today.
I have about 150 units left.
I sent this guy some money for 3080s a month ago and never heard back despite multiple messages. Buyer beware.
I also sent money for a batch of CA3080s several weeks ago, making payment, rather foolishly with the benefit if hindsight, by Friends & Family...
Nothing received, and no response to PMs or emails.
Anyone have any idea what is going on with seanpark??
Haven't received anything either :hmm:
jersupereq
Post by jersupereq » Tue Nov 13, 2018 10:14 pm
ICa showed up today!
jaidee
Post by jaidee » Thu Nov 15, 2018 9:00 am
And out of the blue, my CA3080s turned up today - which makes it even more strange that seanpark is not responding to PMs/emails. I hope he is OK...
jbdiver
Post by jbdiver » Thu Nov 15, 2018 9:06 am
jaidee wrote:And out of the blue, my CA3080s turned up today - which makes it even more strange that seanpark is not responding to PMs/emails. I hope he is OK...
Yeah, mine showed up as well. The problem is that I ordered a new set of 3080's from Small Bear a week ago, and now I have two sets of 3080s. Grrrr.
Synth Con Meo
Post by Synth Con Meo » Thu Nov 15, 2018 1:28 pm
I still never got a response back from him about me wanting to buy a set from him. So I will probably just order my set from Small Bears myself.
elmegil
Post by elmegil » Fri Nov 16, 2018 2:04 pm
PCBs and enclosure arrived in Chicago this morning :goo: :hail:
Very professionally packaged and wrapped, thank you SO MUCH Fitchie!
With wrap
Without wrap
Synth Con Meo
Post by Synth Con Meo » Fri Nov 16, 2018 2:29 pm
elmegil wrote:PCBs and enclosure arrived in Chicago this morning :goo: :hail:
With wrap
Cool! I've been trying to track my shipment but it doesn't appear to have gotten any closer to delivery.
Edit: just checked again, looks like it actually might be in the States now atleast. Did USPS finish the delivery?
elmegil
Post by elmegil » Fri Nov 16, 2018 2:53 pm
Synth Con Meo wrote: Edit: just checked again, looks like it actually might be in the States now atleast. Did USPS finish the delivery?
I didn't see who physically left it at the front door, but yeah, as of yesterday, my tracking (even in "detail") just said "sorted" in Antwerp. I hadn't been trying USPS tracking yet, because there wasn't a clear indication of handoff like I've seen other times I've had shipments from Europe.
Part of my reason for posting was to give hope to other folks waiting in the US. Chicago is probably closer to a "hub" than some, but it seems likely the packages are all here in the US now, at the very least.
Fitchie
Post by Fitchie » Fri Nov 16, 2018 5:08 pm
Thank you for the pictures and nice to see that the parcels ended up in the States !
It looks like the tracking information is not that accurate, but hopefully everyone will be delivered quickly...
Fitchie
Post by Fitchie » Fri Nov 16, 2018 11:02 pm
Here is the information as I can see in the shipping manager for all US parcels:
Glossary:
  • Aangemaakt -> Label created
    Onderweg -> Parcel on the go
    Geleverd -> Delivered to the customer
I am looking for another partner for future deliveries to the United States, BPost seems very slow and the provided tracking information is not accurate at all.
EdBrock
Post by EdBrock » Mon Nov 19, 2018 7:30 pm
PCB's, panel and enclosure arrived today, beautiful packaging job, perfect!
Thanks Fitchie!!!!
I thought I would build a few modules to see if I liked it and guess what happened......
Synth Con Meo
Post by Synth Con Meo » Tue Nov 20, 2018 12:29 am
EdBrock wrote:PCB's, panel and enclosure arrived today, beautiful packaging job, perfect!
Thanks Fitchie!!!!
Yeah mine showed up on my doorstep today too. I concur about the packaging, very nice. I need to start ordering my components now. :tu:
Fitchie
Post by Fitchie » Tue Nov 20, 2018 1:43 am
All,
Nice to hear everyone is served and thank you all for the great feedback about the packaging.
:cheesy:
As there a 5 members who have not responded neither completed the order form,
5 kits are available again !
Please send a PM or mail to info@vocoder.eu if you are interested.
jbdiver
Post by jbdiver » Wed Nov 21, 2018 6:29 pm
The kit arrived in Minneapolis two days ago. Looks awesome and very professional job. Now I just need to source all the components and find some time to build. :)
elmegil
Post by elmegil » Sat Nov 24, 2018 1:20 pm
Group Buy for the CONEC backplane connectors is started over here:
viewtopic.php?p=2954530#2954530
Please post there if you would like to participate. Intent is primarily focused on US and Canada, but we won't turn anyone away (assuming you're willing to pay shipping.... :) )
elmegil
Post by elmegil » Mon Dec 17, 2018 4:12 pm
elmegil wrote:Group Buy for the CONEC backplane connectors is started over here:
Some updates on this, including possible pricing and different sourcing options, again anyone on the US side of the ocean who's interested, please weigh on in that thread.
Fitchie
Post by Fitchie » Tue Dec 18, 2018 9:11 am
3 kits are still available !
The ideal gift for under the Christmas tree. 8-)
