R*S Serge Divide and Compare
Author R*S Serge Divide and Compare
NU
I've officially come down with the Serge bug and I'm intrigued by this module. I love logic in general but I'm specifically wondering about audio range use of the divider (RS description says it's possible). I can't find any demos (CGS version neither).. anyone have experience or thoughts?
lasesentaysiete
I have an Edelweiss I panel (CGS board) and the divider does audio rate. So do the logic modules. I can only assume that the R*S is the same.
NU
Thanks! Forgive me, but what exactly results from using logic at audio rates? Varying cycle length, so.. varying timbre?
J3RK
One example is that XOR can be used as a crude (read, "squared off") ring modulator. You'd want to run the output of any of these through an AC coupled module or offset generator though, as they'll be outputting unipolar signals. (0 to +) so the AC coupled module or offset would help turn it into an audio signal.
