200e modules that produce midi clock?
Author 200e modules that produce midi clock?
jesselucas
Trying to use a 200e System as a master midi clock source. I read in the 200e/h manual you can use the 225m to have midi out. What modules, if any, would send their clock over the bus and midi out with the 225m? Also, is there a better way to achieve a midi out clock than with the 225m?
Leoespejo
252e.....
Can work as Midi master and as a Midi slave....
I don't know of any other Buchla module with a Midi out.
rayce
Maybe some sort of trigger to midi clock device could work for you? Would allow you to use a lot of modules as master clock.
The koma box looks like it might do the trick.
https://koma-elektronik.com/?product=rh301-rhythm-workstation-utility- tool
