Doepfer A-155/154 Sequencer using with 5MU System ?!
Author Doepfer A-155/154 Sequencer using with 5MU System ?!
Ricochet
I'm looking to combinate a Doepfer Sequencer A155/157/154... in combination to my future DotCom-system.
Are there speaking anything against this plans ? seriously, i just don't get it
Are there some helpful tips which I should keep in mind ? hmmm.....
thx
Gerd
ppkstat
Nothing wrong with that but
1) The two will need separate (and different) power supplies
2) We will need adaptors for the cables (very easy to find) or you can make custom cables.
if you solve these two then everything will work fine.
defutura
Alternatively, you can use an adapter module or box:
https://synthesizers.com/q122.html
http://www.lunar-experience.com/assets/downloads/599.pdf
http://www.lowgain-audio.com/ (scroll down to the UTL-4)
Ricochet
that's sure thumbs up
Question is : are the output voltages (range) useful ?! FUUUCCKKKK!!!
defutura
Ricochet wrote:
...are the output voltages (range) useful?
The received wisdom seems to be to have enough attenuators/amps to scale any voltages that need scaling, otherwise you'll be fine.
That said, chances are you can just plug and play, and everything will be just hunky dory.
Myself, I use an Analogue Systems keyboard with my MU setup, and the gates and triggers work just fine.
Here are some older threads where this is discussed:
https://www.muffwiggler.com/forum/viewtopic.php?t=193679
https://www.muffwiggler.com/forum/viewtopic.php?t=139163
https://www.muffwiggler.com/forum/viewtopic.php?t=102927
https://www.muffwiggler.com/forum/viewtopic.php?t=82183
https://www.muffwiggler.com/forum/viewtopic.php?t=80773
