Projectile meditation
MUFF WIGGLER Forum Index -> Synth Noise
Author Projectile meditation
Nelson Baboon
Some martial arts horror zen movie from the 40's.
https://soundcloud.com/ancient-eyeball-recipe/sets/projectile-meditati on
[soundcloud url="https://api.soundcloud.com/playlists/411476498"]
Good stuff! thumbs up
It looks like Soundcloud changed things again but it seems to make things harder meh
https://help.soundcloud.com/hc/en-us/articles/115003565128
What they say to do doesn't work here but I saw that my example in the following thread was still functioning:
https://www.muffwiggler.com/forum/viewtopic.php?p=2516099#2516099
So I messed around with the code a bit and got it working and stripped it down to its simplest form:
So below is all you should need, just replace the playlist ID number with the one you want:
Happy New Year! Hug
Nelson Baboon
John - you have done your good deed for the day. I am presupposing that you haven't done any others....
Thanks! That should be posted in a sticky somewhere.
edit - but where did you grab that id# from?
I had already done other good deeds today but compensated by stepping on an ant and farting in a crowded elevator.
To get something as important as the ID it should be much simpler than it is but . . . . .it's not too hard to reach with the following steps:
1) Click the Share icon under the playlist (circled here in red)
2) In the window that opens click Embed, then click the Code window and copy its contents
3) Open a text editor and paste the Code contents into it. Look for the ID number (circled here in red), copy it and paste it into a URL template you've saved somewhere.
I'll attach a little text file with a template string in it here you can copy and use.
Nelson Baboon
wow. not exactly straightforward......
and btw, that ant was my mother, punk.
Here's an update after helping someone else in another thread. https://www.muffwiggler.com/forum/viewtopic.php?p=2727972#2727972
I realized a shorter URL will work. Just make sure to use the correct one since track and playlist IDs are different. I'll attach a text file version of the below image.
