passive attenuation for serge
Author passive attenuation for serge
pelang
Hi,
i am trying to build a set of passive (flying) attenuatiors but in the banana world it seams not so easy as with eurorack models (no ground).
Anyone has done something like this ?
Permette
Hi.
Nice !
In your way, i would first use megahom pots instead of kilohoms but you may even never completely attenuate the signal and i gess you might have some strange behavior with some module/patch configuration.
Otherwise, better just add a third banana in, for grounding on a panel banana ground.
It will still fly with this third cable.
Cheers !
pelang
thanks
will try with megohm pots. Wouldn't mind if there is a bit of siginal left...
